I want to have one virtual machine running on a separate monitor for short periods. any good and free software for this?- i wanna have 2 people using 1 pc at the same time running 2 instances of tf2. is this possible? sorry i am a noob. btw my cpu supports vt-x and vt-c and virtualisation from intel but its only a ht dual core so i was only gonna run easy games.
https://linustechtips.com/topic/754672-virtual-machine-help/
i dont see your issue
My Personal Computer
CPU: AMD - Ryzen 5 1600 3.2GHz (OC 3.8) 6-Core Processor
Cpu cooler DEEPCOOL Gamer Storm CAPTAIN 240EX WHITE
Motherboard: MSI - B350 TOMAHAWK ARCTIC ATX AM4 Motherboard
Memory: Corsair Vengeance DDR4 3000MHz RAM 8x3
Storage: SAMSUNG 850 PRO 2.5" 256GB SATA III
Storage:SAMSUNG 850 PRO 2.5" 500GB SATA III
Video Card: RTX 2060
Case: NZXT - S340 Elite (White) ATX Mid Tower Case
Power Supply: EVGA 550 B3 550W
Peripherals
Monitor: Acer XF240H 24" TN Free-Sync ,144 Hz
Keyboard: Corsair k95 RGB platinum
Mouse: Razer basilisk
Headset: Hyperx cloud alpha pro
https://linustechtips.com/topic/754672-virtual-machine-help/#findComment-9544457
3 minutes ago, Ethan Meskin said:
how about virtualbox- its the most reccomended one on other sites?
Running games in a VM based off a program like VirtualBox and VMWare is not going to work. The hardware such as the GPU is emulated.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/754672-virtual-machine-help/#findComment-9544472
1 minute ago, Ethan Meskin said:
ok, not even not gpu demanding games like minecraft? what then?
Even Minecraft won't run good (if it will load).
Main System: Phobos
https://linustechtips.com/topic/754672-virtual-machine-help/#findComment-9544485
1 minute ago, tt2468 said:
Don't run vms at all. You have a dual core. Dual cores are already underpowered. Don't put more load on them.
its just for light gaming for an hour or 2. minecraft can run on a single core, and tf2 is fine on a dual core- 3.5ghz. It is hyperthreaded by the way
https://linustechtips.com/topic/754672-virtual-machine-help/#findComment-9544499
you ca also use sandboxie idk if you can set keyboard to a diffent one in sand boxie
Peripherals
https://linustechtips.com/topic/754672-virtual-machine-help/#findComment-9544521
It doesn't matter. It's a bad idea. You need one core per vm for the os, not to mention one core for the host. And we're not talking threads, we're talking cores.
My native language is C++
https://linustechtips.com/topic/754672-virtual-machine-help/#findComment-9546049
8 hours ago, snortings said:
Yes but you want 2 users, so lets do some maths.
1 Core for OS + 1 Core for Each User = 3 cores
thats not how cores work, you can share them, and with something like tf2 thats very lightweight cpu won't be a issue.
29 minutes ago, Ethan Meskin said:
ok, i guess, but will it not work bcus hyperthreading. ik it wont be good, but is it possible?
What OS are you on?
For windows run hyper-v, for linux use kvm
But there is no way to play games in the vm's their virtual gpu's just don't allow that.
https://linustechtips.com/topic/754672-virtual-machine-help/#findComment-9549284
What OS are you on?
can i not work out gpu passthrough if i have virtualbox and 2 gpus?. im on windows but i wanna run a linux vm for linux use and light gaming (2 gamers one cpu style)
https://linustechtips.com/topic/754672-virtual-machine-help/#findComment-9549411
virtual box doesn't support gpu passthrough on windows.
If you on linux, use kvm its faster and more flexable
https://linustechtips.com/topic/754672-virtual-machine-help/#findComment-9549468
Just now, Ethan Meskin said:
g4560 and rx 470 with 8gb ram. i can add a second gpu easily but itll be old barely good enough
you can do this with tf2 just fine then.
Install linux on it.(id personally run fedora)
Install kvm on there with virt-manager and make a vm that used the dgpu.
Use the igpu for fedora.
https://linustechtips.com/topic/754672-virtual-machine-help/#findComment-9549965
ok, and what about ubuntu- i already have it on my vm (its pretty slow and no gaming but it works as linux)
also what about softXpand duo pro? on windows it lets you run 2 games on 2 screens simultaneously.
also how do you work out dual keybaords. also how to dual boot? i have a second hdd i could try idk
https://linustechtips.com/topic/754672-virtual-machine-help/#findComment-9549981
You need to install linux(ubuntu will work) on the hardware, not in a vm.
Normally multiseat software(like the one made by microsoft) won't let you play games in  a vm due to directx errors. Just make the installer and it will manager the dual boot.
https://linustechtips.com/topic/754672-virtual-machine-help/#findComment-9549992
