Thermaltake Smart Series
Go to solution Solved by AlwaysFSX,
Just now, IsraChido said:
Ok, and the CX450M of Corsair is better?
It's okay. It won't set your system on fire like people think it will, and it's definitely not as bad as ThermalTake's Smart serious (seriously it was awful from the day I bought it).
Here's a community list on the forum of recommended power supplies across different budgets.
I plan to buy a Thermaltake 550W Smart Series Bronze but i don't know if it will be good for my system i don't have a high budget.
But i want to know if this Power supply is good.
PD: The pc will have a i3 7100 and a gtx 1050 ti, 8 GB Ram, 2 TB HDD etc.
But also i wanna upgrade the pc in 1-2 years.
https://linustechtips.com/topic/754289-thermaltake-smart-series/
I'd try and get at least a Tier 3 from the PSU Tier List.
A good 1 that isn't expensive is the seasonic M12ii 520
Going w/ a lesser quality PSU just brings too many risks regarding possible failure in the PSU, potentially causing damage to your whole system. Not to mention possible house fires.
Current System Specs:
CPU: Intel I5-7660K; CPU Cooler: Coolermaster Hyper 212X; Thermal Paste: IC Diamond 7 Carat; Motherboard: MSI Z270 Gaming Pro Carbon;
RAM: Kingston HyperX Fury Black 16GB (2 x 8gb) DDR4 - 2400; SSD Storage: 1TB Samsung 850 EVO; Storage: 2TB Seagate Barracuda 7200rpm;
GPU: Gigabyte Geforce GTX 1070 8gb G1 Gaming; Case: NZXT Phantom 530 Black; PSU: EVGA Supernova G2 650W 80+ Gold, OS: Windows 10 Home
https://linustechtips.com/topic/754289-thermaltake-smart-series/#findComment-9540659
https://linustechtips.com/topic/754289-thermaltake-smart-series/#findComment-9540667
That or a Seasonic S12ii 430W, whichever is cheaper.
I'd get the G4560 (very close performance to the similar i3-6100) or a G4620 (literally IS a cheaper i3-6100) and use that extra cash for an RX470 or RX480 4GB
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
https://linustechtips.com/topic/754289-thermaltake-smart-series/#findComment-9540674
According to the tier list "yes." I'd try and find a Corsair CXM (Grey Unit) (Tier 3)
https://linustechtips.com/topic/754289-thermaltake-smart-series/#findComment-9540676
Also try and fit an SSD in there if you can, will definitely help speed up the PC.
https://linustechtips.com/topic/754289-thermaltake-smart-series/#findComment-9540680
