4690k OC Help
Go to solution Solved by WelshDdraig,
These are the options I have on my CPU to give me a stable 24/7 overclock on my i5 4690K on the ASRock Z97 Extreme 4.
Bare in mind, there may be features that are unavailable on your board or vice versa. So take these as a guideline only, for example:
I do not know how good the voltage delivery is on the Z97 Aniversary, so depending on that, adjust your voltage to what is needed/safe.
Under the Advanced Tab for the CPU Configuration
From the OC Tweaker screen. Note: What I found out in my case as the settings used for the pre-set 4.5GHz overclock was good enough for a 4.7GHz overclock, even with a slight voltage decrease - ASRock compensative for weaker chips or an average of the chips they tested with, so experiment till what you find is too little or too much for a stable overclock.
Not signed in
(I dont know about oc but i will try to help)
well, i see from the top right that the default is 100mhz and what you changed is the same...
Remember to quote me (or someone else), otherwise we won't going to recieve your answers...
PC Specs                   PCPartpicker full performance builds (from350$-1250$)
https://linustechtips.com/topic/754250-4690k-oc-help/#findComment-9540250
6 minutes ago, thunderfire123 said:
I did change from BIOS and restarted
run XTU. Clocks should boost.
https://linustechtips.com/topic/754250-4690k-oc-help/#findComment-9540278
If you just want it to boost to the new overclock when doing work, then do what @DildorTheDecentsaid.
If you want it to stay at that speed 24/7, even when at idle, going into the bios and turn off any power saving features, such as intel Speedstep, and if there is a specific option for a static clock speed, see if it is enabled (some boards won't have this option.)
Ryze of the Phoenix:
CPU:      AMD Ryzen 5 3600 @ 4.15GHz
Ram:      64GB Corsair Vengeance LPX DDR4 @ 3200Mhz (Samsung B-Die & Nanya Technology)
GPU:      MSI RTX 3060 12GB Aero ITX
Storage: Crucial P3 1TB NVMe Gen 4 SSD, 1TB Crucial MX500, Spinning Rust (7TB Internal, 16TB External - All in-use),
PSU:      Cooler Master MWE Gold 750w V2 PSU (Thanks LTT PSU Tier List)
Cooler:   BeQuite! Prue Rock 2 Black Edition
Case:     ThermalTake Versa J22 TG
Passmark 10 Score: 6096.4         CPU-z Score: 4189 MT         Unigine Valley (DX11 @1080p Ultra): 5145         CryEngine Neon Noir (1080p Ultra): 9579
Audio Setup:                  Scarlett 2i2, AudioTechnica AT2020 XLR, Mackie CR3 Monitors, Sennheiser HD559 headphones, HyperX Cloud II Headset, KZ ES4 IEM (Cyan)
Laptop:                            MacBook Pro 2017 (Intel i5 7360U, 8GB DDR3, 128GB SSD, 2x Thunderbolt 3 Ports - No Touch Bar) Catalina & Boot Camp Win10 Pro
Primary Phone:               Xiaomi Mi 11T Pro 5G 256GB (Snapdragon 888)
https://linustechtips.com/topic/754250-4690k-oc-help/#findComment-9540298
32 minutes ago, thunderfire123 said:
What and how do i do that?
click benchmark tab and run XTU.
https://linustechtips.com/topic/754250-4690k-oc-help/#findComment-9540474
3 minutes ago, thunderfire123 said:
Is XTU Intel Extreme Tuning Utility? if so, just run a benchmark and it will change the clock speed?
Yes. If you run a benchmark or game the CPU should turbo to 4.5 or whatever.
https://linustechtips.com/topic/754250-4690k-oc-help/#findComment-9540499
I already have Speedstep disabled, also turbo disabled
https://linustechtips.com/topic/754250-4690k-oc-help/#findComment-9540715
2 hours ago, thunderfire123 said:
Fixed the benchmark issue but only runs at 3.5ghz
Not signed in
Since your motherboard, the z97 Aniversary is similar to my Extreme4 - as in same generation and same manufacturer, if you give me a few minutes, I'll have a look in my bios and see what I've got done and see if that will be of any help to you.
https://linustechtips.com/topic/754250-4690k-oc-help/#findComment-9541456
Not signed in
https://linustechtips.com/topic/754250-4690k-oc-help/#findComment-9541615
  Reveal hidden contents
Not signed in
Thank you so much, tried all the settings and i can see the higher cpu frequency now. Just need to change the voltage and stuff for my overclock. Not sure what the issue was.
https://linustechtips.com/topic/754250-4690k-oc-help/#findComment-9541695
Not signed in
What do i set the CPU Cache ratio and CPU cache voltage relative to CPU ratio? Also is Vcore voltage the voltage to change when overclocking?
https://linustechtips.com/topic/754250-4690k-oc-help/#findComment-9541708
CPU Cache works best if you can maintain it 1:1 to your core speed. So if you're at x47 for core you should have cache at x47. However a lot of CPUs can't handle this so a good sweet spot is usually around x40 or x41 .
And yes, Vcore is what you adjust for overclocking. Make sure you're using the offset mode and not adaptive as it will overvolt like crazy under heavy load.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
https://linustechtips.com/topic/754250-4690k-oc-help/#findComment-9541733
Thanks does CPU Cache voltage matter?
https://linustechtips.com/topic/754250-4690k-oc-help/#findComment-9541919
In my experiments with both a 4670k and 4790k, no it didn't seem to make a difference so for my boards (Asus Z87-A and Gigabyte Z87X-UD3H) it's always set to a base of 0.8v and Adaptive mode on, it never exceeds Vcore levels. That's not to say it won't make a difference for you however, every motherboard overclocks differently and every CPU is built different so you will have to experiment and test. And retest. And test some more. It takes a while to dial things in nice and tight but it's worth the time. My 4790k for instance can maintain stock clocks (4.4 Turbo) at 1.15v which helped provide the base for my 24/7 4.7GHz overclock at 1.24v (VCore Offset +.044).
CPU VRIN on the other hand can make a difference and it's a good idea to set it to about 1.8V-1.9V, it will help keep things stable if you go for a high overclock. Mine for example is set to 1.85V.
https://linustechtips.com/topic/754250-4690k-oc-help/#findComment-9542043
