My specs are as follows:
CPU:              AMD Ryzen 1700
Motherboard: Asus Prime X370-Pro
RAM:              Kingston HyperX 2x16GB
GPU:              AMD RX480 8GB (haven't decided which varity I want to go with)
PSU:              SIlverstone Strider ST85F-PT (850W 80+Platnium rated)
Storage:         WD Black 256GB (NVMe M.2 SSD)
Those parts are already bought and is on the way to my house, and I was looking for a case to enclose all of this in, and I am having a hard time deciding on a case that I would like and fit the requirements for what I have planned in the (hopefully not too distant) future.
I would like to do a custom watercooling loop with another RX480 in CrossFire, but I also do not want a big case.
I would like your help on a case that would be able to fit the cooling parts for my (planned) system.
P.S. Also, an advice on what is recommended or the optimun rad size (in total for all 3 components) for my intended build would be helpful.
Thanks in advance.
https://linustechtips.com/topic/753944-questions-on-a-case/
Hmm, well the problem is, the Custom Cooling loop, the issue is not rad space, but the probelm is with the Res/pump setup, i'd suggest most  Phanteks cases, since they seem to be mid tower with all the support, Also, you can get the NZXT S340 but youll need a very thick rad or a 280
Main PC:| CPU: Ryzen 5 2600 @ 4.1, MOBO: Asus B350 PRIME , RAM: LPX Vengance 2400 16gb kit, GPU: 980Ti Poseidon Platinum 6gb
                PSU: SilverStone Strider Gold Evolution 1200w , CASE: HAF 932  HDDs:240gb EX900 HP NVME 6TB (2x3 Seagate Barracuda)
                COOLING: ThermalTake Contac Silent 12
Laptop:MSI GL62 7RD  CPU: Core i5 7300HQ, RAM: 16GB 2400mhz, :GPU GTX 1050 2GB: HDDs: 256gb adata NVME + 1TB HDD
love all brands, will go for whats cheaper for my needs
https://linustechtips.com/topic/753944-questions-on-a-case/#findComment-9537420
Don't do crossfire. If you want more performance buy a better GPU.
https://linustechtips.com/topic/753944-questions-on-a-case/#findComment-9537422
CPU:              AMD Ryzen 1700
Thanks in advance.
Fractal Design always does a great job with cases that are custom loop friendly. I would honestly recommend giving them a look. The recommended rad size (at least according to Jay fro Jayztwocents) is the biggest one that will fit in your case. He also consistently says longer is better then thicker.
https://linustechtips.com/topic/753944-questions-on-a-case/#findComment-9537427
Phanteks offer great water cooling cases at the entry level you have the enthoo pro m and enthoo pro or if you have the money you can always pick up the enthoo primo.
check out their cases in the link - http://www.phanteks.com/index.html
CPU-I7 4790
COOLER-Be Quiet Pure Rock Slim
MOBO-Gigabyte Z97 HD3
RAM-8GB G.skill Ripjaws X
GPU-Gigabyte GTX 1060 6GB G1 Gaming
SSD-Kingston SSDnow 240GB
HDD-Segate Barracuda 1TB
PSU-Zalman ZM 550w Goldrock Semi-Modular psu
CHASSIS-ThermalTake Core X31
https://linustechtips.com/topic/753944-questions-on-a-case/#findComment-9537446
I agree with this, don't plan multi GPU from the off, it should be thought of an upgrade path down the line
Thanks in advance.
Theres a lot of good cases out, for a potential crossfire + CPU set up I would suggest a minimum thick 360. ideally a normal 360 + a 240. I use a thick 240 and a normal 360 at the moment for a 1080 GTX, mobo vrms and a 4790k, temps are good. If you go with a single rad you're gonna need to run the fan speeds high to keep the temps down.
For 2x 970's, 4790k and vrms I used 2x 360 + 240 rads but that was an extreme dual loop rig
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/753944-questions-on-a-case/#findComment-9537474
would it not help for 3D modeling and rendering?
7 minutes ago, BluJay614 said:
thank you guys for your suggestions. I will take a look at them!
https://linustechtips.com/topic/753944-questions-on-a-case/#findComment-9537476
thank you for your input @stealth80!
I was actually thinking of adding a second GPU if I felt like I need more performance, but with the VEGA not too far away, I may even go that route entirely.
https://linustechtips.com/topic/753944-questions-on-a-case/#findComment-9537511
