How do I improve speed without ethernet?
We pay for 76mb/s internet and when you connect straight through ethernet cable it gets pretty much that, low 70s. My PC gets about 10mb/s on wifi but I mostly use homeplugs, which give me 25-30 mb/s. Is there a faster method than homeplugs? I don't really see why the download speed is slowed from 70 to 30 on homeplugs.
Is there any ideas on how to improve my download speed? Ping is fine... usually like 5ms when I test on speedtest which is excellent. it just DL that im concerned about.
GTX 3080 Ti ROG | Ryzen 5600X | MSI Tomahawk B550 | 32GB 3600MHz | Corsair 850e | HAF X | WD SN850X | Asus MG287Q 1440p 144Hz
https://linustechtips.com/topic/753294-how-do-i-improve-speed-without-ethernet/
Sounds like a hardware problem. Get a newer AC access point and an AC wireless adapter for your PC.
Corsair 900D | MSI MPower Max Z87 AC | i7-4790K @ 4.7Ghz | 1080 Ti SLI | 16GB Corsair Vengeance Pro 2400
XSPC Raystorm | EK-FC Nickel GPU block/backplate | 2x Alphacool UT60 480mm & XT45 240mm | 11x Linus Edition NF-F12
Schiit Modi/Magni 2 Uber | 5" KRK Rokit G3 | KRK 10S2 | Acer Predator X34 | Dell S2716DG
Your best bet is to first test out the connection through a cable, and see what speed you get.  Then I suggest upgrading your wireless access point to something with at least AC 1200 bands.  Which will give you good wireless network throughput.
You also should make sure your computer you are connecting through wireless has at least AC 1200 networking capability.  If it does not, you can purchase a wireless network card which can connect via PCIE or USB and give you the network throughput you need.  Keep in mind that wifi will never be as fast as wired in normal circumstances.  And that you should be as close to the access point as possible, and have a good access point, that has good wireless networking throughput.
6 minutes ago, nerdslayer1 said:
get better router, move closer to router.
Agreed, and don't use PowerLine. That can be a MAJOR disadvantage for the speed. For instance, my speed coming in is 200/20, but I get 8/1 over PL.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
Use RJ-45
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
Just now, PCGuy_5960 said:
Use RJ-45
That's ethernet. You realize that, right?
Main System: Phobos
Really? Jk, I know :P
I figured you did, it's just not useful for OP.
Main System: Phobos
As I said, I get 70+ mb/s via ethernet.
We have the Asus RT-N66U router which is supposed to be quite good right?
My wireless card is pretty crappy though I suppose. But my phone only gets 4mbps wifi from my room where my PC is. There are two brick walls between my PC and my router. I am not sure if getting stronger wireless kit will help.
I can't use ethernet as my PC is to far away and it would mean wiring it through the house which we are not gonna do lol :)
You could look in to MOCA 2.0 adapters if you have Coax by your router and in your room. Just one catch.... MOCA adapters can be a little pricey, plus you need to make sure you have MOCA compatible spliters as well as a MOCA filter on the main cable line coming in to your house.
