The only problem i have with MSI is their customer support. They make pretty good products. However after having to RMA the same motherboard 3 times before i could get it so it wouldn't die when i over clock past 5.5Ghz. So yes they're a good manufacturer, But i'd have my fingers crossed when you buy from them that you get a good board.
Please quote/tag ( Found by typing @DarrenP) In all posts directed at me. I do not check my current content.
Intel Core i7-4790K - Gigabyte Z97X-UD5H-BK - 16GB Corsair Vengeance Pro 1866Mhz - EVGA GTX 980 - 256GB MX100 - 2TB WD RED - 900D - H100I - Corsair HX1050 - DNS 320L 2x2TB Seagate Barracuda
https://linustechtips.com/topic/75297-help-pleas-motherboard/#findComment-1031816
okay... how do i know if its good? :P
https://linustechtips.com/topic/75297-help-pleas-motherboard/#findComment-1031818
1. Buy motherboard
2. Install
3. Turn on
4. ????
5. Profit. (hopefully)
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
https://linustechtips.com/topic/75297-help-pleas-motherboard/#findComment-1031826
1. Buy motherboard
2. Install
3. Turn on
4. ????
Also how do you know if it's good? Read the box before you buy it. They're good at marketing and they make great Motherboards. However some are just shit. I've killed two of their motherboards when over clocking a 3770K to about 4.5Ghz. The one i have now lasted until 5.5Ghz and i wasn't pushing any farther with the cooling i have. Now for an APU i think you're just fine with one of their motherboards. Their customer support isn't the worst i've seen. However no where near the best.
https://linustechtips.com/topic/75297-help-pleas-motherboard/#findComment-1031838
and is this a good one ?
AMD A-Series A10-6800K 4.1GHz Socket FM2
I find them very good. APU's are awesome for budget builds!
For example, i'll be building an APU rig here for work soon. Just for the light stuff i do at work. You have the best APU on the market, and for general usage and light gaming they're amazing.
https://linustechtips.com/topic/75297-help-pleas-motherboard/#findComment-1031843
Are going to get a GPU? If no then get an APU.(Yes, that one is fine)If you are getting a GPU then get the FX6300. Or maybe even an Athlon X4 750K.
Quote me to get a reply!
https://linustechtips.com/topic/75297-help-pleas-motherboard/#findComment-1031858
LOOK! i have got the
MSI FM2-A85XA-G65 - ATX but i wonder what processor i shud GET! ? thats all for now
https://linustechtips.com/topic/75297-help-pleas-motherboard/#findComment-1031867
i think im getting the A10-6800K 4.1GHz then! :D and i know i have ask alot but do you know eny video card that is good for gameing?
I think you should reconsider your game plan. What's your budget for this entire build?
https://linustechtips.com/topic/75297-help-pleas-motherboard/#findComment-1031907
Is your username therussianpotato? Yes? There you go!
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/75297-help-pleas-motherboard/#findComment-1031919
no its wackoTacko99 -___-
I'd like for you to come up with a budget bud. Then we can better help you okay?
https://linustechtips.com/topic/75297-help-pleas-motherboard/#findComment-1031936
OK 4000? is that good or more?
Go ask your parents how much they're willing to spend. $4000 is more then almost any parent i know would spend on a computer for their kid.
https://linustechtips.com/topic/75297-help-pleas-motherboard/#findComment-1031954
we don't need buget's were wer going ;)   naa i dont know i don't have a buget... :P is that bad? i will just use all the money it takes! but i just need some thing that can play game att high ress
7870 XT/7950/7970/R9 280X/290. I'd say 7870 XT for an Athlon.
https://linustechtips.com/topic/75297-help-pleas-motherboard/#findComment-1031956
The post I passed and didn't feel like pressing back to quote it.
Just being a smartass, as usual. But seriously. That A10 is badass, for an APU.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/75297-help-pleas-motherboard/#findComment-1031957
