I can use any resolution between 2k and 4k on 4k monitors right?
Solved by NoisanceRitual,
1 hour ago, mariushm said:If the monitor doesn't like it, you can always enable Scaling in the video card's configuration panel... then the video card would always send a 4K image to the display no matter what resolution you actually have configured or switch to - the video card will automatically resize (zoom) the image to fit in a 4K rectangle , (and preserving the aspect ratio of the image if you chose so)
wow ok nice.
What about using a 50inch tv 4K on my pc instead of a normal pc monitor?
Will i have the same behavior and available resolutions?
