APC SMART UPS?
16 hours ago, stratege1401 said:you can find this figures on tom's hardware, on the ups calculator page from schneide,
concerning the psu, you simply go to hp part for DL360....
now, for my academic world, i been working in that business for over 27 years now, and at least i know how to calculate the VA ratio to see if an ups fit, not rolling dice.
more source, in your language : https://www.easycalculation.com/physics/classical-physics/ups-power-requirement.php
I an't rolling dice, have been running APC UPS systems for 10 years. I am somewhat of a APC fan boy lol.
Have everything from the little 450VA rackmount in a 2 person branch office upto a 16KVA symmetra in HQ.
Using the power supply spec is not a good way of determining power draw.
Out of all my boxes the only one of them that gets truely thrashed as its the main database server, its a cisco C220 with dual Xeon 2667v2 CPU's (8 core, high clock speed database sku) with 128GB of RAM, hardware raid, 2 SSD's in raid, 2 x 2TB enterprise HDD's and 10Gb lan card and I am only seeing this.
This is an extreme case, most servers are basically a near flat line. My dual xeon servers idling along are only in the region of 150-200W, If you are going to thrash the box add another 100W per socket.
So provided he an't running graphics card in those boxes, he will be idle along at 300-400W, and peaking at maybe 800W if he has dual CPU's and were thrashing them. So a 1500VA UPS is about right, as he has plenty of overhead. I do not like running my UPS's over 70% load.
For more comparison's here are my two esxi boxes, Dell R730's with dual oct core xeon's and 386GB of RAM.
The only thing you really have to think about is the inrush current when sizing UPS systems where there is not plenty of head room. ie popping circuit breakers on the UPS input or output, if turning overything on at once, vs staggering the startup, but I am talking about whole racks of equipment here.
The biggest factor when choosing the right UPS is the actual quality of the UPS, there is plenty of junk out there, I inherited some 600VA shitters from the previous IT guy when I started at my current job 7 years ago and in testing they could only reliably switch about 150W of load, when switching from mains to UPS battery.
APC, Liebert, Eaton are the main ones that will see that are reputable bands in the main stream.
