Mjello fellow master race
I'm looking for at PCI-e cable, short, to use in a custom build I'm currently working on. I wan't to have my gpu lying down (like the motherboard) to save space, as I'm trying to make it as small as possible. Anyone know about a cheap cable? Also I have never used such a cable before, I'm only aware that they exist, so is there anything I should be warry about when using such a cable?
i7 7700K @ 4.8 Ghz (Kraken x52 aio cooler)
EVGA GTX 980 SC
Gigabyte GA-Z270XP-SLI Motherboard
EVGA SuperNOVA 750W G2 Power Suply
Phanteks Eclipse P400
Acer 144 hz monitor
https://linustechtips.com/topic/749877-cheap-bendable-pci-cable/
1 minute ago, TheManTheLegendTheRph said:
You can't use cheap cables. You need to get a 1000$ wireworld cable!
what?
EVGA GTX 980 SC
Acer 144 hz monitor
https://linustechtips.com/topic/749877-cheap-bendable-pci-cable/#findComment-9492816
1 minute ago, deXxterlab97 said:
What you need is PCIE riser
I think they all work the same so look up reviews of it before buying
Like this?
https://www.computersalg.dk/i/588822/delock-riser-card-pci-32-bit-with?utm_source=EDBpriser&utm_medium=edbpriserLINK&utm_campaign=EDBpriser
EVGA GTX 980 SC
Acer 144 hz monitor
https://linustechtips.com/topic/749877-cheap-bendable-pci-cable/#findComment-9492843
Actually, they don't... They need to be properly insulated, otherwise you will run into many weird issues.... Good PCIe risers cost $100 or more..
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
https://linustechtips.com/topic/749877-cheap-bendable-pci-cable/#findComment-9492858
https://linustechtips.com/topic/749877-cheap-bendable-pci-cable/#findComment-9492866
Did not know. Thanks for the info
You're welcome :D
https://linustechtips.com/topic/749877-cheap-bendable-pci-cable/#findComment-9492871
You will want to get a good quality extension or riser that is properly shielded or you can run into stability of performance issues. Here is an example of a good one:
https://mnpctech.com/case-mods-gaming-pc-liquid-modding-custom-computer-mnpctech-overclock-cooling-fan-grills/ezdiy-pci-express-16x-black-flexible-riser-graphics-card-extension-cable.html#/product/830
https://linustechtips.com/topic/749877-cheap-bendable-pci-cable/#findComment-9492910
Thank you alle for the respons. Knowlegde is always nice. Even better than a brand new Lamburghini.
I didn't know they were that expensive though.,
EVGA GTX 980 SC
Acer 144 hz monitor
https://linustechtips.com/topic/749877-cheap-bendable-pci-cable/#findComment-9496981
22 hours ago, Jesmo said:
what?
He's poking fun at a video Linus made about super-expensive cables that work no better than cheap-O discount bin cables. (HDMI)
https://www.youtube.com/watch?v=Zgy5fX-VPCs
Personal Rig:
[UPGRADE]
CPU: AMD Ryzen 5900X    Mb: Gigabyte X570 Gaming X    RAM: 2x16GB DDR4 Corsair Vengeance Pro    GPU: Gigabyte NVIDIA RTX 3070    Case: Corsair 400D    Storage: INTEL SSDSCKJW120H6 M.2 120GB    PSU: Antec 850W 80+ Gold    Display(s): GAOO, 现代e窗, Samsung 4K TV
Cooling: Noctua NH-D15    Operating System(s): Windows 10 / Arch Linux / Garuda
[OLD]
CPU: Intel(R) Core(TM) i5-6500 @ 3.2 GHz    Mb: Gigabyte Z170X-Gaming 3    RAM: 2x4GB DDR4 GSKILL RIPJAWS 4    GPU: NVIDIA GeForce GTX 960    Case: Aerocool PSG V2X Advance    Storage: INTEL SSDSCKJW120H6 M.2 120GB    PSU: EVGA 500W 80+ Bronce    Display(s): Samsung LS19B150
Cooling: Aerocool Shark White    Operating System(s): Windows 10 / Arch Linux / OpenSUSE
https://linustechtips.com/topic/749877-cheap-bendable-pci-cable/#findComment-9497360
I have used the EZDIY riser cable, and it is definitely the best made one under $100, but it still suffers the issue that it is highly sensitive to bending, the same way that the cheapest ones are. Still, I believe that it is better quality enough to justify the 2x-3x cost compared to the cheapest ones.
Looking to buy GTX690, other multi-GPU cards, or single-slot graphics cards:
https://linustechtips.com/topic/749877-cheap-bendable-pci-cable/#findComment-9507650
If you don't care which way the GPU faces, you are much better off with a hard (PCB) 90 degree riser card, versus a flexible riser cable. The fact that it doesn't flex means that you get better signal integrity and it will last much longer.
https://linustechtips.com/topic/749877-cheap-bendable-pci-cable/#findComment-9507654
