Started work on another video in Sony Vegas pro and I found that in two of my clips the audio was not synced. So, I went and watched the clips in my files explorer and all the audio was synced up then. I restarted the program and the problem is still happening. Did I hit something or is it that I just need to re-import my clips?
https://linustechtips.com/topic/748021-video-audio-not-syncing-right/
Have you also tried to resync the audio in Vegas?  Try shifting the audio or video tracks manually to match up.
That is not dead which can eternal lie.  And with strange aeons even death may die. - The Call of Cthulhu
A university is not a "safe space". If you need a safe space, leave, go home, hug your teddy & suck your thumb until ready for university.  - Richard Dawkins
Tried that, couldn't get it right and some parts are synced others are not. Nothing happened in the clip that I wanted to use anyway
Is the video file variable FPS? Because if it is, and the editing software doesn't support it, the audio will not be correctly synced.
“Remember to look up at the stars and not down at your feet. Try to make sense of what you see and wonder about what makes the universe exist. Be curious. And however difficult life may seem, there is always something you can do and succeed at.
It matters that you don't just give up.”
-Stephen Hawking
