Best 1440p monitor
Jman20nnsss
Hey guys, i'v recently thought of upgrading my screen to a monitor with a 1440p resolution but im not sure which is the best, so far my research has pointed me to the Dell u2713hm so i was wondering if this monitor is really good for gaming and i have 2 GTX 670s in SLI so running games on this resolution is not going to be a problem, i mostly play BF4 And DOTA 2 and im currently using the BenQ 2420T but a friend of mine is looking to take that off my hands so i was wondering if the change from 120Hz to 60Hz will be significant and will the Dell monitor be good for gaming
I can't really notice the difference between 120 and 60, but some people might be able to, imo dell has the best 1440p with their ultrasharp, its response time and input lag are a bit more, but its not really noticeable imo.
go with a korean one
Intel3570k  at  4.5ghz 1.300v  Noctua NH-D14    Gigabyte Gtx 970 G1   AsrockZ77 Extreme 6/TB4     Corsair8Gb vengeance memory    120GB Corsair Force SSD     1TB WD black      NZXT Switch 810
If you want to spend a lot of money on a good quality 1440p monitor then get the ASUS PB278Q. Otherwise get a QNIX QX2710 Evolution II.
Intel Core i7-8700K @ 4.8GHz | Corsair H110i GTX | EVGA RTX 2080 XC | Asus ROG Maximus XI | Intel M.2 nVME SSD 1TB | Samsung 850 EVO 2X2TB | 32GB G.SKILL Trident Z 3200MHz CL14 RAM | EVGA SuperNova GS 1050W | Kept cool & quiet in a Fractal Design Define R5 Window with all Noctua fans
Korean monitor if you're on a tight budget
PB278Q or U2713HM are great choices otherwise
CPU: Intel i7-4770k MOBO: Asus Maximus VI Formula RAM: G.Skill RipJawsX 2x8GB 1600Mhz GPU: Asus GTX 780 DCuII CASE: Phanteks Enthoo Primo STORAGE: ADATA SX900 256GB / WD Caviar Blue 1TB PSU: Corsair AX760 760W MONITOR: Dell Ultrasharp U2312HM KEYBOARD: Ducky Shine 3 MOUSE: Logitech G602 http://linustechtips.com/main/topic/106614-project-insert-name-enthoo-primo-rigid-acrylic-red/
