LG 34UM58-P Monitor
A350-941XWB
Hi
I'm about to build my own gaming pc for flight simulator (X-Plane 11)
My components are:
Case; Phanteks Enthoo Evolv ATX tempered glass
CPU: Intel Core I7 7700K
GPU: Nvidia GTX 1080ti
MoBo: Asus Prime Z270A
RAM: 16gb Corsair Vengeance LED white
CPU cooler: Corsair H115i
PSU: Corsair RM750X
Storage: 2x Samsung 850 EVO 250gb in RAID 0 and 2x 2tb WD black in RAID 1
Is the LG 34UM58-P Monitor good for gaming? I'm just playing X-Plane 11 and some other similar games.
Does anyone have experience with it and otherwise is there any other 34 inch monitor in the same price category?
Thank you in advance!
While it would be good for gaming the 2560x1080p resolution sweet spot is 29 inch, if you want a higher panel you should consider 1440p
Personal Desktop":
Luna, the temporary Desktop:
It's fine for gaming, however 34 inches diagonal is much too big for a 2560x1080 image. It's more appropriate for 3440x1440.
I recommend the same monitor I have, which is the LG 29UM67-P. It's ultra cheap nowadays, and the panel quality is phenomenal for the price.
New Build (The Compromise): CPU - i7 9700K @ 5.1Ghz Mobo - ASRock Z390 Taichi | RAM - 16GB G.SKILL TridentZ RGB 3200CL14 @ 3466 14-14-14-30 1T | GPU - ASUS Strix GTX 1080 TI | Cooler - Corsair h100i Pro | SSDs - 500 GB 960 EVO + 500 GB 850 EVO + 1TB MX300 | Case - Coolermaster H500 | PSUEVGA 850 P2 | Monitor - LG 32GK850G-B 144hz 1440p | OSWindows 10 Pro.
Peripherals - Corsair K70 Lux RGB | Corsair Scimitar RGB | Audio-technica ATH M50X + Antlion Modmic 5 |
CPU/GPU history: Athlon 6000+/HD4850 > i7 2600k/GTX 580, R9 390, R9 Fury > i7 7700K/R9 Fury, 1080TI > Ryzen 1700/1080TI > i7 9700K/1080TI.
Other tech: Surface Pro 4 (i5/128GB), Lenovo Ideapad Y510P w/ Kali, OnePlus 6T (8G/128G), PS4 Slim.
Thanks, the 29 inch monitor is about the same price like the 34 inch. I'm probably taking the 34 inch.
Does anyone have a picture of a 34 inch 2560x1080p monitor?
Is there a 34 inch monitor with a 3440x1440p resolution for under 400
Nope. Not even the cheapest Korean lottery monitors are that low.
Prices bottom out at ~600-700 USD for that resolution. Name brand monitors at $800+.
Ok.
Is the LG 34UM58-P okay for non competitive gaming and as a productivity monitor?
Just now, A350-941XWB said:
Ok.
It's fine, but the pixel count does not change with that monitor compared to its 29 inch counterpart. The image might appear more grainy and pixelated.
Do you have a pic of a 34 inch monitor with the same pixels?
No I don't. I'm on my phone atm, otherwise I would look around a bit.
