Gaming Sound Card?
Go to solution Solved by Oshino Shinobu,
The onboard is good enough. If you're going to upgrade sound, you'd probably be wanting to go for an external DAC and AMP.
Hey!
Before im going through all topics without an search option, i ask right here in a new one.
Which Sound Card would be good for some Gaming, listening to musik and having overall good sound?
I need something that isn't that overkill and expensive. Something around $60 to $120.
Or is the Asus Z270-A Prime good enough for good sound? I really don't know.
Give me every tip you know. I want them! ;)
(Ah and by the way, sorry if my english is not the yellow from the egg. I come from germany)
-Icefly
https://linustechtips.com/topic/747516-gaming-sound-card/
just use onboard audio, only case iv needed to use a separate card has been when the onboard has been busted or iv needed more outputs
Builds:
https://linustechtips.com/topic/747516-gaming-sound-card/#findComment-9466571
On board is pretty good currently. I would get a dac rather than a sound card but even then it probably won't make any noticable difference in games.
CPU: I7 6700K 4.4Ghz @ 1.29v | GPU: MSI Gaming X 1070 8GB | MOBO: Gigabyte z170x Gaming 3 | RAM: 16GB 2800Mhz DDR4 Kingston HyperX
SSD's: 240GB + 500GB SSDs | PSU: Corsair CS 550M | COOLER: Be Quiet Silent Loop 240 | CASE: Corsair 400C
https://linustechtips.com/topic/747516-gaming-sound-card/#findComment-9466590
23 minutes ago, Icefly said:
Oh okay.. I thought a sound card would matter a bit more than onboard sound.
I guess im going for the Hyper X Cloud 2 Headset.
I really liked your profile pic, and yes onboard or even your graphics card sound chip if you use HDMI/DP is good enough, focus the money on a sweet headset and you're set, audio pci-e cards are more of a music studio kind of rig [:
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/747516-gaming-sound-card/#findComment-9466687
