Help with a server build
41 minutes ago, Windows7ge said:What's your budget to build the server? If you don't really have one then what kind of number would you want to keep the server under?
You can swamp out any of these items for anything else but this would work for a web server.
Intel Xeon E5-2630 v3
ASRock EP2C612D16C-4L (It's a dual socket motherboard but you can run it with one CPU. Option for future expansion.)
Noctua NH-D9DX i4 3U
RAM: KVR21R15D4/16 (If you install 1 CPU install 4 sticks in the blue slots. If you install 2 CPU's then install 8 in the blue slots)
I've been trying to locate a mini-redundant PSU that is compatible with ATX computer chassis but I'm just not seeing any. You can buy a regular non-redundant PSU such as the Corsair RM850X but it's not recommended for a server environment.
As for the chassis itself I don't know if you want a tower or something rack mountable.
For storage I don't know how much you need or what type of software you plan to run so I'm not sure what to recommend in that regard.
