Changing my laptop's network card
Hello everyone
I am currently using XPS 15 9560 as my daily laptop to school and some homework, nonetheless I also use this for streaming and web games.
The stock wifi card that came with XPS 15 is Killer ac 1535 which according to the internet it is reliable and all that great stuff, but I encounter some problem instead
First, my laptop does detect 5 ghz network in my house, but it can't connect it for some reasons
Second, the card will disable itself or disconnect when it is under load which in my case 40mb/s download and 5mb/s upload.
I searched it up online and looks like there are people out there with the same problem.
I hear that many of them replaced it with Intel AC 8260
but I am not really sure if there is any different with wifi cards especially laptop's...
if there isnt i guess i can just purchase one in NCIX
https://linustechtips.com/topic/743997-changing-my-laptops-network-card/
2 minutes ago, nerdslayer1 said:
you can try it out or order a replacement part, it sounds like you have a defective part.
I am not sure if it is a defective part because I have the same problem with XPS 13, and many people have the same wifi problem using the same wifi card.... If it is really defective, I think Dell really have to choose their parts carefully...
that sucks, generally yes the new card should work, use an ethernet cable for windows automatic drivers.
The original one it comes with do suck. Order one on eBay the same size. You need a special screw driver to open it up. I think it voids warranty though but the dell guys never noticed it when i got mine replaced. Make sure to download the Intel drivers first. Install it, boot up first uninstall the dell WiFi driver software thing, then the intel. I have done it with my XPS 13.
Main Gaming and Streaming PC: http://pcpartpicker.com/user/Vinsinity/saved/TjwVnQ
Ultrabook and College Laptop:
XPS 13 9350:
i5-6200U
8GB RAM
Samsung PM951 250GB M.2 Solid State Drive
Workstation Laptop:
Sager NP8672 (P670SG):
i7-4720HQ
32GB (4 x 8GB) CORSAIR Vengeance Performance
Samsung 850 EVO 250GB M.2 Solid State Drive (Boot Drive)
Samsung 950 PRO 512GB M.2 Solid State Drive (Video Drive)
Crucial MX100 250GB 2.5" Solid State Drive (Secondary SDD Storage)
Western Digital (Blue or Black) 1TB 2.5" 7200RPM Internal Hard Drive (Storage Drive)
GeForce GTX 980M 4G
8 hours ago, Andy Yu said:
Hello everyone
I replaced the WiFi card in my sisters HP laptop before. The big thing is verifying that the WiFi card will work. Lots of Manufactures like to white list cards in the BIOS. If you use a card not on the list, it will not work. Once you know is compatible, order it. Most computers will have access areas on the bottom, or like my laptop my bottom comes offer entirely. Then its about finding the card, disconnecting the antenna cables and removing the screw holding the card in. Pull the card out and install the new one, do everything in reverse. Should take maybe 10 min.
Upgraded my sister from a single band Wireless N card to a Dual band AC card.
