Will this cpu cooler fit?
Im looking at some heatsinks for the fractal node 202.
Cryorig C7 - 47mm height
beQuiet! Shadow Rock LP - 50.4mm height
and
Phanteks PH-TC12LS Slim - 47mm height
the question is, will the shadowrock fit inside the node 202? on Pcpartpicked it doesnt show up in the cooling options so i am just wondering. all say that they will support AM4, so im not worried about them not fitting if thats the case
https://linustechtips.com/topic/743977-will-this-cpu-cooler-fit/
