Hey, this is my first post and its been a long time coming  so i need a case  preferably with the following  features
atx
h100i v2  &
Rm1000i compatible
as silent as possible
and if possible a type c usb front io
thanks
looks are really not a factor cause itll sit under my desk hidden away
https://linustechtips.com/topic/743116-case-recommendation/
Budget?
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
https://linustechtips.com/topic/743116-case-recommendation/#findComment-9417951
Not sure if there are any cases with front USB 3.1. Since you didn't specify your budget I'm going to assume money isn't an issue for you. I will look for the front USB 3.1 though.
"You think your Commodore 64 is really neato! What kind of chip you got in there a Dorito?" -Weird Al Yankovic, All about the pentiums
PC 1(Lenovo S400 laptop):
CPU: i3-3217u
SSD: 120gb Super Cache mSATA SSD
HDD: Random seagate 5400rpm 500gb HDD
RAM: 8GB Crucial DDR3-SODIMM
OS: Windows 10 education
PC 2(2014 Mac Mini):
CPU: i5-4260u
HDD: 5400rpm 500gb
RAM: 4gb DDR3 (soldered on :( )
OS: MacOS Sierra/Windows 10 pro via bootcamp
https://linustechtips.com/topic/743116-case-recommendation/#findComment-9418011
Fractal Design Define R5 is very quiet, modular design, very easy to access front and bottom dust filters, and incredible cooling options/radiator support.
i7 4790k @4.7 | GTX 1070 Strix | Z97 Sabertooth | 32GB  DDR3 2400 mhz | Intel 750 SSD | Define R5 | Corsair K70 | Steel Series Rival | XB271, 1440p, IPS, 165hz | 5.1 Surround
PC Build
Desk Build
https://linustechtips.com/topic/743116-case-recommendation/#findComment-9418075
if i can get all of them then yea budget isnt a concern but if not then id preffer the cheapest possible .... looks are really not a factor cause itll sit under my desk hidden away
that was my first thought too but its stupidly overpriced in india
https://linustechtips.com/topic/743116-case-recommendation/#findComment-9418246
Get the master case 5 and add sound dampening foam. It's a ver modular case so you can customize it a lot.
CPU: i3-3217u
CPU: i5-4260u
HDD: 5400rpm 500gb
https://linustechtips.com/topic/743116-case-recommendation/#findComment-9418259
thats about 11k in my money if possible id want  around 7-8 k at most cause like its just a box to keep things and connect to things for me  and my build is about as standard as you can get with a high end atx board and aio so.....
https://linustechtips.com/topic/743116-case-recommendation/#findComment-9418285
In Win cases have USB 3.1 on the front! However they're not built to be quiet like the Fractal Design Define S
https://www.newegg.com/Product/Product.aspx?Item=N82E16811108480&cm_re=805-_-11-108-480-_-Product
I imagine silence is more important though.
https://linustechtips.com/topic/743116-case-recommendation/#findComment-9418910
silence is more important also it sort of hurts to pay so much for glass :P
https://linustechtips.com/topic/743116-case-recommendation/#findComment-9421411
That isn't true 3.1. That is actually USB 3.0 because there is no front panel 3.1 header on most motherboards. Either the product info on newegg is incorrect (happens a lot. Not really inwin's fault if whoever made the page accidentally put 3.1 instead of 3.0) or they are referring the USB type C port to USB 3.1 gen 1. I might be wrong about some of this so correct me if I am wrong about any of this.
http://www.cmstore-usa.com/cm-masterbox-5-black-combo-w-additional-ssd-hdd-kit/
They have a cheaper version called the masterbox 5. This is the version with an extra hard drive bay just in case you need it. If you don't get the regular one. I actually really with I had gone with this one for my PC build instead of the J180 because this is much more customizable. I'm not trying to fanboy out over cooler master though because other manufacturers make great cases aswell. Another option is this: http://in.pcpartpicker.com/product/7H2rxr/phanteks-case-phec416pscbk. You can add sound dampening foam to that as well
CPU: i3-3217u
CPU: i5-4260u
HDD: 5400rpm 500gb
https://linustechtips.com/topic/743116-case-recommendation/#findComment-9421527
would 3.0 ports work as 3.1 if i connect them to a 3.1 header on the motherboard ? cause my motherboard has 3.1 support
0not a fan of the masterbox yea its modable but like i dont really need that  what i do need is dust filters also the phanteks one is cheaper so ...  would it be a better option for silence ? the cooler master over the phantex ? what i think i basically need is something cheaper and as quiet as r5
(cheaper cause the indian market sucks for good budget builds )
https://linustechtips.com/topic/743116-case-recommendation/#findComment-9421740
There isn't a 3.1 header. I think that the page has false advertising which is actually illegal in most countries.
It would be fine but I don't know if sound dampening foam is included. I will take a look.
It does according to phantek's website http://www.phanteks.com/Eclipse-p400s.html
This is actually a really nice case too. Sound dampening foam always works the same. there are exceptions like thickness of the foam but usually in pc cases, it will tend to be similar to preserve airflow. I don't know how quiet it is though. I would expect it to be like the R5 in terms of acoustics but you can't really tell.
CPU: i3-3217u
CPU: i5-4260u
HDD: 5400rpm 500gb
https://linustechtips.com/topic/743116-case-recommendation/#findComment-9421932
yep thanks so much it seems that the p400s is the one thats not going to be beat anytime soon ill get that
but tell me something if my motherboard has 3.1 headers will that work with 3.0  im not very clear on that
https://linustechtips.com/topic/743116-case-recommendation/#findComment-9422107
There is no motherboard with 3.1 headers yet. There won't be any for a couple years. What motherboard do you have?
CPU: i3-3217u
CPU: i5-4260u
HDD: 5400rpm 500gb
https://linustechtips.com/topic/743116-case-recommendation/#findComment-9425450
*finger snap* I think you're right. It advertises the 19 pin USB 3.0 pin connector and I read else-ware it runs at 3.0 speeds.
R.I.P Hopes and dreams
https://linustechtips.com/topic/743116-case-recommendation/#findComment-9428787
go for a Naxonia or (my personal choice) BeQuiet Case. The have a wide variety of cases in different sizes with and without sidepanel-windows.
NZXT got also silent cases, but it seems to be not their main focus.
CPU Intel Core i5 4670, 3.4GHz Motherboard ASRock Z97 Pro4 RAM Kingston HyperX Fury Black 8GB, 1833Hz GPU AMD Radeon R9 380 4GB OC Case BeQuiet Silent Base 800 Storage Seagate ST2000DX001 SSDH  PSU BeQuiet PurePower L8, 400W Display(s) Samsung 2 x 22" Cooling BeQuiet Dark Rock Pro 3 Operating System Windows 10
https://linustechtips.com/topic/743116-case-recommendation/#findComment-9428844
On 2/26/2017 at 1:52 AM, Demiurge said:
z270 maximus ix code that has a 3.1 header so i wanted my case to be as compatible as possible
Oh wow, it does. Guess I was wrong about that. Still, It's a very new technology and not many cases have adapted it yet. I'm even surprised about cases with USB type C although most if not all use USB3 making it a basically an adapter.
No hopes and dreams are dead yet. in a few years, USB 3.1 front panels will be just as standard as UBS3 front panel today. Although there is a chance that won't happen but that chance is very low.
CPU: i3-3217u
CPU: i5-4260u
HDD: 5400rpm 500gb
https://linustechtips.com/topic/743116-case-recommendation/#findComment-9433644
