Need help installing fresh windows.
Upgrading my PC put brand new pieces in no second hand stuff, PSU, MOBO, RAM, CPU, HDD i have been trying to install windows i have got it on CD & Pen drive changing boot options in BIOS to boot from which ever one i was trying at the time, disabling all others as well when i save and restart it just reboots and goes straight back to bios, not too sure what going wrong i have done this once or twice before I'm not the best with computer but i know the basics, when i did this the first time on my old HDD it was simple the mobo picked up the disk straight away and i began the windows install but doesn't seem to be having any of it, its been rattling my brains for past few hours!
PLEASE HELP IF ANYBODY HAS ANY ADVISE / TIPS.
https://linustechtips.com/topic/742257-need-help-installing-fresh-windows/
Did you buy the CD from a store?
Best of myself(1000th post)
Vista
Core i5-8400
8GB DDR4
GTX 1050ti
1TB 7200RPM HDD
MSI H310M PRO-VD
EVGA 450BT
Cooler Master masterbox lite 3.1
Arctic Cat
Core 2 quad q8200
8GB DDR2 ECC
GTX 550ti
1TB 7200RPM HDD
Dell precision t3400 motherboard
2 hours ago, DaviidJH said:
depends who's asking 8)
You didn't answer my question
Vista
Core i5-8400
8GB DDR4
GTX 1050ti
1TB 7200RPM HDD
MSI H310M PRO-VD
EVGA 450BT
Arctic Cat
Core 2 quad q8200
8GB DDR2 ECC
GTX 550ti
1TB 7200RPM HDD
No i didn't buy it from a store :)
did you just dump the .ISO file on the CD
Vista
Core i5-8400
8GB DDR4
GTX 1050ti
1TB 7200RPM HDD
MSI H310M PRO-VD
EVGA 450BT
Arctic Cat
Core 2 quad q8200
8GB DDR2 ECC
GTX 550ti
1TB 7200RPM HDD
Using a USB drive to install windows, i have managed to finally get bast the bios and start the installation although im greeted with this god awful window with the  A required CD/DVD drive device driver is missing" or "A media driver your computer needs is missing"
Anybody know how i can get past this, i have tried every single USB slot in the computer but no good when i press browse all i see is "Cd drive (D:)" and "boot (x:)
appreciate any help i can get, ive been battling with this trying to get an OS on it for hours now!
Press shift +f10 to bring up the console
type
Diskpart
List disk
Select disk 2
Clean
(using Clean command in diskpart will delete all partitions on the selected disk)
Exit
(exit from Diskpart)
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
LABEL="Windows"
ASSIGN LETTER=C
EXIT
EXIT
Basically you want to wipe the main disc you selected, create a partition, format it as NTFS, then assign a letter and name
4 minutes ago, DaviidJH said:
i used the windows 7 usb tool to do it everything seemed to have worked fine there like what if i tried different windows or will your solution work @Aytex
Try the win10 iso
