CPU doesn't turn on! Need some help
Go to solution Solved by HelloitsLuke,
Update:
My PC is now up and running. Turns out I just suck balls and the plugs weren't properly snapped into place. Thanks everyone!
Hello everyone.
So my PC just basically "died" on me yesterday. A few hours after using it moderately (2-3 hours of gaming + some hours of youtube/social media), my PC no longer posts.
Also this happened after a very short power interruption. I don't have a UPS installed but I do have an extension cord with surge protection, if that matters.
What I do know is:
1. The PC turns on
2. After turning on, it shuts down and turns on again
3. No display on both the GPU and iGPU
4. No beep sounds occurred (Iirc if it beeps, means the RAM sticks are bad)
My current conclusion: The PSU might have just given up on me (?).
Anyone else who can think of the possible reasons why it doesn't post? Would like to know your thoughts on this matter. Thank you in advance!
CPU: Ryzen 7 3700X @4.3Ghz All-Core with Stock Cooler
Motherboard: Asrock X570 Phantom Gaming 4
RAM: Patriot Viper 32GB DDR4 RAM @3000Mhz
GPU: MSI Ventus RTX 2080 Super 8GB
PSU: Corsair RM750X 80+ Gold Fully Modular
Storage 1: Phison 500 GB NVME SSD
Storage 2: WD Blue 1TB NVME SSD
Case: Inwin 146 ATX Case
Peripherals
Mouse: Logitech G Pro X Superlight
Keyboard: Razer Huntsman Tournament Edition
Headset: Drop x Sennheiser PC38x
Monitor 1: LG 27GL850-B 1440p @144hz Nano-IPS Monitor
Monitor 2: Asus VG248Q 1080p @144hz Gaming Monitor
Monitor 3: Asus VG259Q 1080p @144hz IPS Gaming Monitor
https://linustechtips.com/topic/740402-cpu-doesnt-turn-on-need-some-help/
6 minutes ago, HelloitsLuke said:
Hello everyone.
What I do know is:
1. The PC turns on
Anyone else who can think of the possible reasons why it doesn post? Would like to know your thoughts on this matter. Thank you in advance!
What PSU do you have?
Thermaltake Smart PSU 630 Watts 80+ Bronze
Peripherals
22 minutes ago, HelloitsLuke said:
Hello everyone.
What I do know is:
1. The PC turns on
Hmm, I guess you don't have any other hardware to trouble shoot with. Does anything have the magic smoke smell? Any signs of catastrophic failure, if no, then you'll need to validate each piece of the PC jigsaw.
Yours faithfully
10 minutes ago, Megah3rtz said:
Give the full PC specs.
Core i5 2500
8GB RAM 1333 ( G Skill Ripjaws)
GTX 1060 (Gainward Phoenix Edition)
1TB HDD
The abovementioned power supply
17 minutes ago, Firecheetah13 said:
As far as I know, that is a low tier PSU. I think it might have internally surged and fried your motherboard.
Well if the mobo is fried, then nothing should power on, right?
Yeah; what a drag :V
Peripherals
Also would clarify
It turns on BUT does not post
Peripherals
1 minute ago, HelloitsLuke said:
Also would clarify
Any POST codes or anything? Given the age of the PC, maybe just buy parts for a new one or buy one, I hope the GTX 1060 is ok.
Yours faithfully
Hope so too I did shell out my money for it :'( But it's still under warranty, which I'm not sure if it's covered.
1 hour ago, NoGravityPanda said:
Maybe cpu power delivery problem? Try another cpu if you can.
Don't have any spare parts lying around
1 hour ago, Kumaresh said:
OK, so your computer powers up and the fans start spinning and the lights turn on, but the usual BIOS POST beep doesn't happen...... Sounds like your computer is fried.....
Yeah well the GPU turns on too (has an LED indicator), just haven't confirmed if it's dead or not.
Peripherals
Update:
Peripherals
