Best headphones for 150 USD
9 minutes ago, HalfOfALifeLeft said:Open is good, right? I did see the AD700X which are priced at about 100 on amazon. Is there any benefit of the 900 over the 700? (I assume the 900 is more expensive)
On paper the 900 will have slightly more sub bass extension but has a bit brighter treble, whereas the 700 will have slightly less bright treble and slightly less sub bass extension - according to InnerFidelity's charts.
I don't think either of them will sound terrible, but if you prefer something as neutral as possible the 700's would be the best bet if you chose between those two headphones. The reason I brought up the 900s instead was as an alternative to the neutral sound since many people like more of a v-curve even in games, as it pronounces things such as explosions, gun fire, etc.
None of the headphones mentioned so far though will have any type of issue where some frequency band is so loud that the driver will sound muddy, so don't worry about that.
