I bought this cheap Chinese capture converter and the problem with it is that it's losing me a lot of frames (~10% of footage) and the audio captured is of terrible quality.
The tapes are not damaged and are in good condition, plays perfectly on tv.
I tried using many different capture software like virtualdub, virtual vcr, software that came in the disk, etc.. Same results.
Do you guys know a better hardware solution? I really need highest quality possible.
https://linustechtips.com/topic/738910-need-help-digitzing-vhs-tapes/
Dropped frames could be related to:
-Too aggressive compression for your CPU. To save disk space, many capture applications compress the video on the fly, your system must be able to keep up. Try a lower compression, or no compression at all like we did back in the day, but that puts a bigger load on the hard disk, which brings us to...
-Storage system not keeping up. Is your hard disk fast enough to keep writing everything away in real time ? Are there no other processes using the hard disk?
Or, it could just be a crappy capture device...
It's just a crappy capture device, I have a high end gaming pc with ssd so slow system isn't an issue. The device captures lossless as default so no compression.
  • 4 weeks later...
What are on the tapes? Family Videos or Copyrighted movies? If its Family videos then you can look at a service like Yes Video. I used to work at Sams Club and this was the service we used when people needed videos digitized. I dont remember costs and it can take a hot min for them to do it, but it might be a better way.
it's family videos, I don't live in US though.
4 hours ago, Lazarus23 said:
Not sure if I really had that option..
I don't know why not.
Should work with all direct show devices and you just have to add something like "-rtbufsize 800000000" to your existing command line
