it will literally tear apart the entire universe.
(lol, what is this question even?)
https://linustechtips.com/topic/738622-jello-problems/#findComment-9370347
5 minutes ago, Master Jorn said:
Hi, I want to make some jello, but I want it to be firm, can I get away with adding less water, or will the destroy it?
make your own jello experiments, have multiple samples with their water/jello ratio noted on them and test them out to see which one is actually better, it will cost you a few dollars and then you will have the perfect jello mix forever.
you can also control the rate at which they cool off afterwards buy purchasing a refrigerator made for that.
https://linustechtips.com/topic/738622-jello-problems/#findComment-9370361
Well, it's an existential look into our lives, are we the jello, wanting to be firm and perfect, or do we follow the rules of society, becoming soft and weak. These are the things we should think about, stick it to the man, lets show life whos boss!
https://linustechtips.com/topic/738622-jello-problems/#findComment-9370367
I wonder what happens when you mix in some kool aid with the Jello. Or what about some GFuel? (use offercode '$$$' for 0.0900001% off your first purchase of 1000$ or more)
https://linustechtips.com/topic/738622-jello-problems/#findComment-9370373
You can make it more firm by adding less water. Just don't over do it
i7-4790k | MSI Z97 GAMING-5 | Corsair Vengeance 16 GB | Samsung EVO-850 250GB SSD & WD blue 1 TB HDD | EVGA 1070 SC | Red NZXT H440 | Cooler Master G650W
https://linustechtips.com/topic/738622-jello-problems/#findComment-9370374
-moved to off-topic-
https://linustechtips.com/topic/738622-jello-problems/#findComment-9370377
6 minutes ago, Howitz said:
look at that mod's forum profile picture, ryan, did you achieve green fluo jello or what? what did you do for it to be fluo?
I never have jello problems :P
https://linustechtips.com/topic/738622-jello-problems/#findComment-9370409
