Hi,
My computer (upstairs) is connected to the router with an ethernet cable and the other computer (downstairs) is connected through wireless. The router is next to the downstairs computer and my pc is on the other side of the house. Once this other computer is turned on I cannot use the internet due to the really slow speeds. Is there a way to 'split' the internet speed equally, or prioritise my connection?. The max speed my house receives is about 230KB/s
Thanks
i7 4790k, Asrock Pro4 matx, EVGA 980Ti SC+, H60, Patriot Viper 8GB, Samsung 840 Evo 250GB, WD Blue 500GB, Seagate Barracuda 1TB, Corsair CX600M, Fractal Design Arc Mini, Ducky Shine 3
https://linustechtips.com/topic/73797-wireless-prioritesed-over-wired/
your router might just have very poor range
Does this make a difference even if i'm using a Wired connection?
Um, I think you might want to buy a new internet plan. What router isit?
A BT HomeHub 2.0, and its the quickest i can get in my area unfortunately  :(
Wither you have bad range or your router can handle that many users at the same time switch is unusual. Or Too much usage from each computer might be slowing your speed overall. Most likey your 3rd computer is too far away from the router itself.
it might have poor quality ports, or uses all its power to drive the wireless
CPU: i5 3570K @4.5GHz    GPU: R9 290   MOBO: ASUS p8z77-v  RAM: 8Gb corsair vengence   CASE: ARC MIDI  PSU: XFX pro 550W  HDD: 2tb segate baracuda
Read up on some maximum power outputs of wireless.
Anyway, other than all ISP routers being crap, routers don't differentiate from wired and wireless connections because its not their job that's why you can prioritize traffic to a specific host for a specific type of traffic in any way you like, but i doubt that many ISP routers have that feature, speed limiting should be available though so try that. Since you are getting 250 kbps speeds i would say don't bother changing anything it won't help much.
Something wrong with your connection ?
Run the damn cable :)
Check your routers IP for settings, I think mine had some kind of "prioritise gaming and video" bollocks, might wanna try that out. Also a very handy program is Netlimiter 3, it will allow you to restrain the speeds the other pc gets so you get higher speeds (don't tell the one using that pc that though :P). Also WiFi is just as good as ethernet in most cases because most people don't use that much traffic on their (W)LAN
"Great minds discuss ideas; average minds discuss events; small minds discuss people."
Main rig:
i7-4790 - 24GB RAM - GTX 970 - Samsung 840 240GB Evo - 2x 2TB Seagate. - 4 monitors - G710+ - G600 - Zalman Z9U3
Other devices
Oneplus One 64GB Sandstone
Surface Pro 3 - i7 - 256Gb
Surface RT
Server:
SuperMicro something - Xeon e3 1220 V2 - 12GB RAM - 16TB of Seagates
