NZXT S340 vs NZXT S340 Elite
VicRik
Hi guys,
I have been looking around online and I can't find many differences between the two. The only things I could find were the HDMI-passthrough and the tempered glass. Any things I missed that would make it worth the difference? And which one would you get?
Thanks a lot for your help!
PS: Not a native English speaker.
Think the elite has an extra SSD mount thats on the front of the psu shroud, but other than that and what you listed, there's really no difference.
PC - CPU Ryzen 5 1600 - GPU Power Color Radeon 5700XT- Motherboard Gigabyte GA-AB350 Gaming - RAM 16GB Corsair Vengeance RGB - Storage 525GB Crucial MX300 SSD + 120GB Kingston SSD   PSU Corsair CX750M - Cooling Stock - Case White NZXT S340
Peripherals - Mouse Logitech G502 Wireless - Keyboard Logitech G915 TKL  Headset Razer Kraken Pro V2's - Displays 2x Acer 24" GF246(1080p, 75hz, Freesync) Steering Wheel & Pedals Logitech G29 & Shifter
53 minutes ago, VicRik said:
Hi guys,
elite makes it sound cooler
Cable management is slightly improved as well.
3600X @ stocke | 5600XT TUF OC @ 1850 | 2x16 + 2x8 RAM 3200 HD | 1tb Samsung 970 EVO Plus | Lian Li 205M | TT Toughpower Grand RGB 850 | throwaway b450 asus mobo | BQ cooler
One big difference is the crappy PSU filter on the old 340 (one of those flimsy plastic honey comb filters held in by tabs that you couldn't just pull out easily) is replaced in the Elite by the "fabric mesh with plastic frame" thats easily removable from the back.
Old
Image result for s340 psu filter
New
Old
New
I noticed, but nxzt updated the s340 with a similar filter
