2 minutes ago, Electronics Wizardy said:
Water cooling and cooling in general uses very little power, about 10-20w max. your fine with a 400w psu.
That's if you're not overclocking^
If you are overclocking, I'd probably go with 450-500W to be safe.
https://linustechtips.com/topic/737223-power-wattage-help/#findComment-9354929
16 minutes ago, FrankCai said:
https://pcpartpicker.com/list/JTZssJ
That's what i have right now,pc part picker says 375w of power, and im adding a ekwb p360 water loop. How much watt do i really need?
Thx
Your system will use maybe 400W with OC so the 650G2 you chose is good.
https://linustechtips.com/topic/737223-power-wattage-help/#findComment-9355023
