Hey, i have some questions about ryzen
1. Is it worth it?
2. If i did wait would it be more  powerful than an Kaby lake CPU of the same price?
3. how much will they cost
4. How powerful will the APU power be?
5. Will i need a expensive MOBO?
SO MANY QUESTIONSSSSSSSSSS
Best of myself(1000th post)
Vista
Core i5-8400
8GB DDR4
GTX 1050ti
1TB 7200RPM HDD
MSI H310M PRO-VD
EVGA 450BT
Cooler Master masterbox lite 3.1
Arctic Cat
Core 2 quad q8200
8GB DDR2 ECC
GTX 550ti
1TB 7200RPM HDD
Dell precision t3400 motherboard
https://linustechtips.com/topic/736778-ryzen-questions/
How about you wait until it actually launches and every tech publication and their dog takes it upon themselves to answer the questions you and everyone in the tech enthusiast community has.
25 minutes ago, Electronics Wizardy said:
just fucking wait.
Could've waited 5 seconds to post that after my reply, would've been more hilarious.
Quote and/or tag people using @ otherwise they don't get notified of your response!
The HUMBLE Computer:
AMD Ryzen 7 3700X • Noctua NH-U12A • ASUS STRIX X570-F • Corsair Vengeance LPX 32GB (2x16GB) DDR4 3200MHz CL16 • GIGABYTE Nvidia GTX1080 G1 • FRACTAL DESIGN Define C w/ blue Meshify C front • Corsair RM750x (2018) • OS: Kingston KC2000 1TB GAMES: Intel 660p 1TB DATA: Seagate Desktop 2TB • Acer Predator X34P 34" 3440x1440p 120 Hz IPS curved Ultrawide • Corsair STRAFE RGB Cherry MX Brown • Logitech G502 HERO / Logitech MX Master 3
Notebook:  HP Spectre x360 13" late 2018
Core i7 8550U • 16GB DDR3 RAM • 512GB NVMe SSD • 13" 1920x1080p 120 Hz IPS touchscreen • dual Thunderbolt 3
https://linustechtips.com/topic/736778-ryzen-questions/#findComment-9350341
16 minutes ago, v0nn_toaster said:
1. Is it worth it?
  1. wait for benchmarks *
  2. maybe, [see 1]
  3. between 300 and 500$ at the top end , similar to i7 **
  4. people hope for RX460 levels on the gpu and i5 on the cpu , ill say below 460 (but not by a country mile) and maybe i5 cpu perf w/ a 4c/8t? depends really [see 1]
  5. no , a320´s are in the 50$ range (those which are out there on german retailers bundle w/ an a12-9800 for 200€) the better boards wich can OC will be 70~150, i dont see amd pulling an X99 on the mobocosts , they never did ***
https://linustechtips.com/main/topic/736399-ryzen-benchmark-leaked/ [RUMOR, SALT REQUIRED]
** https://pics.computerbase.de/7/6/7/3/3/1-630.1420844628.jpg
*** https://www.csl-computer.com/shop/product_info.php?products_id=13001
RyzenAir : AMD R5 3600 | AsRock AB350M Pro4 | 32gb Aegis DDR4 3000 | GTX 1070 FE | Fractal Design Node 804
RyzenITX : Ryzen 7 1700 | GA-AB350N-Gaming WIFI | 16gb DDR4 2666 | GTX 1060 | Cougar QBX
PSU Tier list
https://linustechtips.com/topic/736778-ryzen-questions/#findComment-9350389
Press the spoiler to shake future orb.
Try again later.
Your guess is as good as mine.
Some day.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/736778-ryzen-questions/#findComment-9350424
1 hour ago, v0nn_toaster said:
It most likely won't be faster than an i7 7700K at 5ghz for single core performance, but you're going to get more cores most likely that makes it a better buy overall, if a game uses 8 threads very well, and you've got an 8c/8t Ryzen chip compared to the 4c/8t Kaby Lake chip, the ryzen chip should be faster assuming clock speeds are close
Ryzen APU isn't due for a while, they will have current gen APU stuff that should get a pretty good boost from using DDR4
With Ryzen you can overclock on a mid range motherboard, so no you don't exactly need an expensive board, though you may want one anyways
https://linustechtips.com/topic/736778-ryzen-questions/#findComment-9350660
Why is AMD blaspheming Zen Buddhism by ripping off its name?  Good question.  Credit to Zen and Buddhist that they don't care lol.
As far as the chip...It will more than likely be on par with what Intel has and AMD will be a viable alternative...so yes it will be worth it.  I seriously doubt it is going to be better though.  Physical cores are better than logical cores, but IPC matters and AMD is not on par with Intel in that regard so AMD's 8 cores = Intel's 4 cores.
If you've waited this long to build a new computer, one more month to find out for sure won't ruin you.
Fractal Design Define C | Intel Core i7 7700k | Corsair H100i V2 | Gigabyte Z270X Gaming 7 | Seasonic Prime 750 | MSI GTX 1080 Gaming X
16gb G.Skill Trident Z | Samsung 960 Evo NVMe 500gb | Razer Black Widow Chroma | Razer Death Adder Chroma | Razer Firefly | Dell U2515H
https://linustechtips.com/topic/736778-ryzen-questions/#findComment-9350676
