Yes, it has no power connectors. What PSU are you/will you be running? I would save up for an RX 470 or 480 (480 is the only one that isn't overpriced somewhat)
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
https://linustechtips.com/topic/736739-radeon-rx-460-question/#findComment-9349934
It has a 6 pin PCIe connector.................................
https://linustechtips.com/topic/736739-radeon-rx-460-question/#findComment-9349938
3 minutes ago, LeXerPrime said:
Hi everyone, just a quick question. Will I be able to run the ASUS ROG Strix 4GB RX 460 via power supply from motherboard? Link to product below:
http://www.ncix.com/detail/asus-radeon-rx-460-rog-a2-134299.htm
Sorry I'm new to graphics cards and all.
So from what I've read, the card draws all it's power from the PCIe slot, but ASUS went and stuck a 6-pin on it anyway as insurance. You can get other versions of the 460 that are PCIe powered only.
Not so, ASUS added a 6 pin for overclocking headroom.
Laptop: Asus GA502DU
RAM: 16GB DDR4 | CPU: Ryzen 3750H | GPU: GTX 1660ti
https://linustechtips.com/topic/736739-radeon-rx-460-question/#findComment-9349939
That's weird, ASUS's website says "0x6-pin"
https://www.asus.com/us/Graphics-Cards/ROG-STRIX-RX460-O4G-GAMING/specifications/
HOLA NIGHT THEMERS
OTHER TECH I OWN:
https://linustechtips.com/topic/736739-radeon-rx-460-question/#findComment-9349944
But then this image, in the gallery of the same page shows the 6 pin.
https://linustechtips.com/topic/736739-radeon-rx-460-question/#findComment-9349955
Yeah, weird... some reviewers have pictures running it with no power connector...
HOLA NIGHT THEMERS
OTHER TECH I OWN:
https://linustechtips.com/topic/736739-radeon-rx-460-question/#findComment-9349966
2 minutes ago, Shiv78 said:
Yea thats what got me confused. Thanks anyways guys. I might consider getting a rx 470 8gb for $250 CAD, not sure if its worth though
https://linustechtips.com/topic/736739-radeon-rx-460-question/#findComment-9349967
Yeah I think someone at ASUS messed up a little there.
I have a 470 8GB (the loud, hot Sapphire one) and it's awesome. But you probably won't need to 8GB, although it is slightly faster memory than the 4GB for gaming, I use mine for 3d modelling so it's useful. If you can, I'd check the price of 480's as well, they may be quite similar.
https://linustechtips.com/topic/736739-radeon-rx-460-question/#findComment-9349974
I'm thinking about this one, MSI 8gb
http://www.ncix.com/detail/msi-radeon-rx-470-gaming-8f-134473.htm?promoid=1382
Seems like the 480s are another $50 on top of the 470s.
https://linustechtips.com/topic/736739-radeon-rx-460-question/#findComment-9349981
May as well then. Aside from probably not needing all the memory, the 470 performs really well at 1080p (especially overclocked) and even at 1080p ultrawide.
https://linustechtips.com/topic/736739-radeon-rx-460-question/#findComment-9349989
