Hello everyone!
I'm using an old HDD and today I was about to buy a WD Blue except my Sata cable which is a 6GB/s one (Pictures below) broke and from what I've read the wd blue doesn't come with cables. My Motherboard, an Asus Z97 Pro-Gamer comes with 4 6GB/s ports and 1 Sata express  port (dont exactly know much about what this means to be honest) but i know that the WD Blue uses 6GB/s cables (correct me if I'm wrong).
So my question is , to connect a WD Blue to my PC i will need my PSU cable and sata III female cables like these ones? (the link is an image to a Nanoxia 4x SATA-III Female).
Pictures of the broken cable in question: its a 7PIN one (the part that goes into the HDD broke, the motherboard end is intact)
https://linustechtips.com/topic/735470-hdd-cable-broken-please-help-me-replace-it/
A normal sata cable. It only looks to be the clip that is broen on yours. So it should still work in theory.. It will just fall  out easy.
man that's not a forumworthy problem, SATA cables are like £2 at maplin
Home PC:
CPU: i7 4790s ~ Motherboard: Asus B85M-E ~ RAM: 32GB Ballistix Sport DDR3 1666 ~ GPU: Sapphire R9 390 Nitro ~ Case: Corsair Carbide Spec-03 ~ Storage: Kingston Predator 240GB   PCIE M.2 Boot, 2TB HDD, 3x 480GB SATA SSD's in RAID 0 ~ PSU:    Corsair CX600
Display(s): Asus PB287Q , Generic Samsung 1080p 22" ~ Cooling: Arctic T3 Air Cooler, All case fans replaced with Noctua NF-B9 Redux's ~ Keyboard: Logitech G810 Orion ~ Mouse: Cheap Microsoft Wired (i like it) ~ Sound: Radial Pro USB DAC into 250w Powered Speakers ~ Operating System: Windows 10 Enterprise x64
Work PC:
CPU: Intel Xeon E3 1275 v3 ~ Motherboard: Asrock E3C226D2I ~ RAM: 16GB DDR3 ~ GPU: GTX 460 ~ Case: Silverstone SG05 ~ Storage: 512GB SATA SSD ~ Displays: 3x1080p 24" mix and matched Dell monitors plus a 10" 1080p lilliput monitor above ~ Operating System: Windows 10 Enterprise x64
Hi @Kingslayer13!
This is a standard SATA cable which you can easily replace with a new one. Furthermore, there is not really a lot of difference between the SATA II and SATA III cables as far as performance goes.
Just keep attention to the specific length you need when you select the replacement and if you want you can specifically check for a cable with locking mechanism which will prevent the drive from slipping out.
Cheers!
If this post helped you, please like and choose it as a best answer.   :)
http://www.wdc.com/en/
