Yes, yes they are doing it so right, this about the only thing the Asian chick is good for.
Available from 3pm to Midnight Eastern Time (GMT-5). (>'-')> <('-'<) ^(' - ')^ <('-'<) (>'-')> You can't stop the kirby dance.
4770k | Gigabyte GTX 970 Mini | Lian Li PC-TU100B | MSI Z87I 2x8GB G.Skill Sniper | Noctua NH-L9i Silverstone Strider 450W SFX | Windows 10 | 2x 250GB 840 Evo Rad 0 1x 1TB WD 2.5" | 25% gaming, 25% CAD and rendering, and 50% web browsing.
https://linustechtips.com/topic/73532-neweggtvdoing-it-right/#findComment-1007607
I think so, and if you look when steve gets up and weirdly touches jenny he has a mini boner :D
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
https://linustechtips.com/topic/73532-neweggtvdoing-it-right/#findComment-1007658
unless your gay yes :P
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
https://linustechtips.com/topic/73532-neweggtvdoing-it-right/#findComment-1007670
does this mean Linus needs to have his wife on the WAN show?
CM Storm Switch Tester MOD (In-Progress) - http://linustechtips.com/main/topic/409147-cm-storm-switch-tester-macro-mod/
       Ammo Can Speaker 02 (Completed) - http://linustechtips.com/main/topic/283826-ammo-can-speakers-02/       A/B Switch V 0.5 (Completed) - http://linustechtips.com/main/topic/362417-ab-switch-v0
     Build 01 - The Life of a Prodigy -  http://linustechtips.com/main/topic/13103-build-01-the-life-of-a-prodigy/             Build 02 - Silent Server 3000 - http://linustechtips.com/main/topic/116670-build-02-silent-server-3000/
https://linustechtips.com/topic/73532-neweggtvdoing-it-right/#findComment-1007861
