Origin BF4 Installation Stuck at 20%
First, copy and move the BF4 files to a new location outside of Origin.
Uninstall DirectX and Battlefield 4 (it will be installed in the Add or Remove Programs).
Move the BF4 files back to the Origin location you copied them from. Uninstalling causes Origin to delete them all. You don't want to redownload it.
Re-install BF4 which will install DirectX with it.
That should fix it. That's what I did and I had the exact same problem.
DirectX doesn't seem to show up anywhere in the Add/Remove programs tool. ![]()
Sorry for the double post, but the thread wouldn't get bumped otherwise.
EDIT: I tried installing once more, it froze at 20% again so then I closed out the installation process, and for some reason it works now, I can launch the game. Weird. :wacko:
