I'll only help if you have a specific problem with a single step. Other than that I'm not going to list every command as that would be doing your homework for you.
[Out-of-date] Want to learn how to make your own custom Windows 10 image?
Desktop: AMD R9 3900X | ASUS ROG Strix X570-F | Radeon RX 5700 XT | EVGA GTX 1080 SC | 32GB Trident Z Neo 3600MHz | 1TB 970 EVO | 256GB 840 EVO | 960GB Corsair Force LE | EVGA G2 850W | Phanteks P400S
Laptop: Intel M-5Y10c | Intel HD Graphics | 8GB RAM | 250GB Micron SSD | Asus UX305FA
Server 01: Intel Xeon D 1541 | ASRock Rack D1541D4I-2L2T | 32GB Hynix ECC DDR4 | 4x8TB Western Digital HDDs | 32TB Raw 16TB Usable
Server 02: Intel i7 7700K | Gigabye Z170N Gaming5 | 16GB Trident Z 3200MHz
https://linustechtips.com/topic/733458-centos-lab-help/#findComment-9315369
16 minutes ago, SCHISCHKA said:
is the title of your subject "computing for idiots"? do you really think people are going to do such easy homework for you?
Chmod  -R 777 /* and your good.
https://linustechtips.com/topic/733458-centos-lab-help/#findComment-9315373
You know what's sad. I have to deal with so many of my client's IT departments exactly the same way.
We'll provide them a detailed list of requirements. How to install the OS, folder structure, mount points, etc, etc. Deadline always "comes and goes". Ask why they're not ready. "having some slight trouble executing". Push to help, find out always they're still on step 1. And it's always something simple like "create folder /output/public"
I've gotten to the point where I have literally written a script so now when client's inevitably ask, I tell them I'll do all their setup work for a fee, charge them more and run my 30 second script.
But this unfortunately seems to be the intelligence level of a LOT of private IT out there. (And I bet they all make way the heck more than me)
Quote
"Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so." - Douglas Adams
System: R9-5950x, ASUS X570-Pro, Nvidia Geforce RTX 2070s. 32GB DDR4 @ 3200mhz.
https://linustechtips.com/topic/733458-centos-lab-help/#findComment-9316890
Sounds like they got hired by smaller firms that don't know how to recognize the experience/skill level of an IT admin.
https://linustechtips.com/topic/733458-centos-lab-help/#findComment-9317131
