2 minutes ago, aeon187 said:
Im 95% in, would it still work?
Im unable to apply pressure Since the motherboard is loose on the right side, would it work? what should I do?
If you can see that it is not all the way in, I would say to support the bottom of your board with one hand, and apply the pressure with the other hand. Even if the board is not loose, you should still do that to avoid flexing the board when possible. That should work for you.
Main Rig: R9 5950X @ PBO, RTX 3090, 64 GB DDR4 3666, InWin 101, Full Hardline Watercooling
Server: R7 1700X @ 4.0 GHz, GTX 1080 Ti, 32GB DDR4 3000, Cooler Master NR200P, Full Soft Watercooling
LAN Rig: R5 3600X @ PBO, RTX 2070, 32 GB DDR4 3200, Dan Case A4-SFV V4, 120mm AIO for the CPU
HTPC: i7-7700K @ 4.6 GHz, GTX 1050 Ti, 16 GB DDR4 3200, AliExpress K39, IS-47K Cooler
Router: R3 2200G @ stock, 4GB DDR4 2400, what are cases, stock cooler
I don't have a problem...
https://linustechtips.com/topic/732210-my-24-pin-doesnt-click/#findComment-9302237
Try and pull it out without toughing the tap. If you can it is not okay, if you can not then it is fine. If it pulls out try putting your hand behind the 24pin on the motherboard to support it when you push it in.
https://linustechtips.com/topic/732210-my-24-pin-doesnt-click/#findComment-9302242
Mine doesn't click. It just goes in but gets locked anyway by the tab.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
https://linustechtips.com/topic/732210-my-24-pin-doesnt-click/#findComment-9302246
@tarfeef101 My friend use a H440 from nzxt...
The case is horrible. doesnt proprelly support the board on that side.. I dont have space to move finger in there.. I will try to boot. if it doesnt will have to take off everything..
NZXT. design by Razer.
https://linustechtips.com/topic/732210-my-24-pin-doesnt-click/#findComment-9302260
It's not always the case. The board can depend too. I've seen some mid ATX boards that have garbage designs. There is an inch strip of board that isn't designed to be supported by standoffs. Very bad design. Cases are designed to fit a variety of boards. They have holes drilled for each standard border size. If your board isn't designed to be supported with standard mounting holes, it's not the case design, it's the board design.
If you cannot get a finger directly underneath that is fine, just put your fingers on the side of the board and and support it the best you can. If it's not in properly, it may come loose during the worst moment, such as Windows update installation, BIOS update, or something else that could do more harm than good. You want solid connections to won't come loose.
https://linustechtips.com/topic/732210-my-24-pin-doesnt-click/#findComment-9302322
@Ryujin2003 I only have place to put my finger, But with the amount Of force I assume it need, It will literally cut/crush my finger.. If I decide to put little peace of card board directly behind the 24 pin, so it protect the board from that pressure would that work ?
https://linustechtips.com/topic/732210-my-24-pin-doesnt-click/#findComment-9302353
I guess the cardboard should work, but I would worry about potentially damaging the solder points on the bottom. But that's me. I baby my gear.
You shouldn't crush or several your finger. It shouldn't need all that amount of force. Just a little but of wiggling to get it in properly. If you look, does it look like the 24pin is seated all the easy in? Is it flush with the connector? I've never heard an audible click before when putting my stuff together.
https://linustechtips.com/topic/732210-my-24-pin-doesnt-click/#findComment-9302365
@Ryujin2003 im missing like 1mm the little clip thing on the side, doesnt secure.. I would like to be has much carefull that I can be, this is very frustrating
I wouldn't worry about brute force. Just support it so the board doesn't crack or bend. And I would just wiggle it a little as your push down. You should not require your whole body weight to apply. If you have to put a bunch of weight into it, something is wrong with the interface or pin connection. In that case, make sure there isn't any debris in the connectors of the MB agreed PSU.
https://linustechtips.com/topic/732210-my-24-pin-doesnt-click/#findComment-9302398
