Display refunded, looking for a replacement
regarding this topic:
Well apparently they thought there was nothing wrong with the display. Fortunately under Dutch law they're obligated to refund items purchased online for 14 days, so I got my money back.
However, I'm not really inclined to purchase a similar screen since it appeared to me this was a clear fabrication fuck-up with the bezel.
Which also means ASUS is off the table. I'm back to looking for replacements. A few contestants are the AOC Agon AG271QX and the Dell S2716DG. With the latter having the benefit of having g-sync. I'm still running a 980.
Any other idea's? Budget can be inferred from the suggestions.
https://linustechtips.com/topic/731917-display-refunded-looking-for-a-replacement/
I'm really gonna strongly suggest gsync. I game at 1080p 144Hz with a 1080 and even with my 1080 and cannot hit 144Hz at all times. I assume that's especially true at 1440p and a 980. Gsync will let you run higher settings and not worry about tearing or even noticing as your framerate bounces from say 110-144Hz or something.
6 minutes ago, Majestic said:
http://www.tftcentral.co.uk/reviews/asus_rog_swift_pg278q.htm
Seems to have the same poor uniformity and edging issues.
Well my MG278Q is working fantastically on my 1060 and calibrating it made the colours excellent. It's a great monitor but obviously I'm a bit biased
i didn't encounter the same issues with Asus TN as IPS while researching for my monitor
That's an F in the profile pic
