Need Help Choosing
Go to solution Solved by Devin92,
If hes gonna overclocking, go get k CPU and z motherboard, if not get non K CPU and h or b motherboard. Otherwise its a waste of money.
What resolution and quality is he playing games on? That will decide the GPU, and as @Gamessys mentioned, if he do more video editing and need its done fast then go for i7.
i helping my friend build video editing + gaming PC with $1200 budget (Video editing use adobe premiere pro)
i got 3 specs
1.
CPU : i7 - 6700
VGA : asus rx480 8GB OC Strix Edition
RAM : 16GB
Storage : samsung 850 Pro 128GB + WDC Blue 2TB
MB : MSI Z170A Tomahawk
PSU : Be Quiet! Straight Power 10 600W CM Modular
2.
CPU : i7 - 6700
VGA : asus GTX 1060 6GB
RAM : 16GB
3.
CPU : i7 - 6500
VGA : asus gtx 1070 8GB dual
RAM : 16GB
https://linustechtips.com/topic/731880-need-help-choosing/
Seeing as though the only things that are different are the CPU and GPU it's depends on whether he does more gaming or video editing and needs more power for one or the other.  If he wants better graphics, fps etc then get the 1070 but if he needs the hyper-threading on the 6700 then get that.
i5 12600k | ASRock Z690M-ITX 32GB Corsair Vengeance LPX DDR4 3200MHz | EVGA 2080 Super Black | Samsung 970 EVO Plus 500GB + 980 1TB | Corsair RMx 650W | Thermaltake Tower 100 White
https://linustechtips.com/topic/731880-need-help-choosing/#findComment-9298289
i got 3 specs
1.
CPU : i7 - 6700
RAM : 16GB
2.
CPU : i7 - 6700
RAM : 16GB
3.
CPU : i7 - 6500
RAM : 16GB
https://pcpartpicker.com/list/PtgXFd
https://linustechtips.com/topic/731880-need-help-choosing/#findComment-9298331
https://linustechtips.com/topic/731880-need-help-choosing/#findComment-9298510
