4 minutes ago, M310N said:
which is better for gaming i7 5820k or i7 6700k
You posted on the wrong section, there is one only for CPUs down on the menu, about the question itself they are close to the same however the 6700k has better single core performance therefore is more advised if you are making a gaming rig, the 5820k is stronger at multi-thread applications and advised for professional work such as rendering material.
They use different motherboards so that is something you should also consider
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/731514-help/#findComment-9294291
