I recently upgraded my home internet from dsl to cable. I now get 200 down 10 up. My Modem/router (netgear c6300) is in my living room, and my pc is in my office, on the other side of the house. I have a range extender so I can connect to ethernet. However, I am getting worse signal on my pc now. I did a speed test before and after (also did a steam download test). Before I was getting the correct speed, but now I am getting worse. On my phone or other wifi devices, I get the correct speed. I tried re-configuring the range extender, but to no avail. Would it be better to set it up as an access point, rather than a range extender? Or should I ditch the extender, and run Cat. 6 cables in my attic? thanks for the help
https://linustechtips.com/topic/730697-home-internet-help/
Agree, wiring it through will save you a lot of headaches in the future too.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/730697-home-internet-help/#findComment-9286215
Do you have COAX near your router and office?  If so, look at Moca 2.0 devices (https://www.amazon.com/Actiontec-Bonded-Ethernet-Adapter-ECB6200K02/dp/B013J7O3X0/ref=sr_1_3?ie=UTF8&qid=1485784502&sr=8-3&keywords=actiontec+moca)
I use that to get 'wired' connectivity to another room and I get gigabit speeds (~110-115MB/s).
https://linustechtips.com/topic/730697-home-internet-help/#findComment-9286442
