a bit overclocking
Go to solution Solved by LogicalDrm,
U14S for 70€, bit better than 212, not so big as D14.
Please stop making so many posts. The question was answered. Noctua NH-D14 or Cooler Master Hyper 212 EVO if you are on a tight budget.
https://linustechtips.com/topic/73061-a-bit-overclocking/#findComment-1001425
What is your budget? I would recommend a Noctua NH-D14 or a Thermalright Silverarrow. If you are on a tight budget the Hyper 212 EVO is a great value
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/73061-a-bit-overclocking/#findComment-1001429
I know most air cooler don't come over 100 euros (thats right euros that about 130 dollars I think)
so not a thight budget
That knocks like a bus (dutch joke!)
https://linustechtips.com/topic/73061-a-bit-overclocking/#findComment-1001442
