Hi there.
I recently built my own system (https://uk.pcpartpicker.com/user/fiddleplayer01/saved/TzWMnQ) and my internal HDD ( Western Digital Blue 1TB 3.5" 5400RPM Internal) isn't being recognised. I'm quite sure that the data and power cables are attached correctly, but it only recognises my backup drive (WD Elements) and the ssd (Samsung EVO). Could someone please help me fix this?xD
Thanks,
Armaan
https://linustechtips.com/topic/730485-pc-wont-recognise-hard-drive/
did you try turning it off and turning it back on again
Best of myself(1000th post)
Vista
Core i5-8400
8GB DDR4
GTX 1050ti
1TB 7200RPM HDD
MSI H310M PRO-VD
EVGA 450BT
Cooler Master masterbox lite 3.1
Arctic Cat
Core 2 quad q8200
8GB DDR2 ECC
GTX 550ti
1TB 7200RPM HDD
Dell precision t3400 motherboard
Reboot the system into the BIOS and check to see if it is detected by the system first.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
40 minutes ago, fiddleplayer01 said:
Thanks. I will do that, just needed some confirmation before RMA'ing it.
did you initialize the disk?  Right click the windows (edit: START) icon and go up to disk management. It should prompt you to initialize the disk and format.  Then the disk will show in device manager
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
He said it wasn't detectable by the BIOS. Windows doesn't affect that does it?
Hello
I'm not certain but it's definitely worth a few clicks to find out :P  I kinda think that it does not show up in bios until initialized but I could totally be wrong
  • 3 weeks later...
Thanks for the reply. It isn't being detected by Disk Management. Should I RMA it?
Yeah, I'd try their support and try everything one more time with them and hopefully they'll RMA for you if it's unsuccessful
