My PSU has a 4-pin power connecter. Mobo has 6-pins
Solved by SpaceGhostC2C,
2 minutes ago, bgibbz said:see if the pcie power connector fits in it. It's a stretch, but that's the only other 6 pin power connector I can think of.
It wouldn't, and it would be a bad idea as for example an 8-pin PCIe connector doesn't have the pins in the right place for an 8-pin CPU connector.
2 minutes ago, Slayerstealth said:My final question is this:
will my 8-pin cpu power connector work with my psu, that has a 4-pin connector?
I think it could work, although I'm not sure whether the motherboard will refuse to boot, or whether it would depend on the CPU model. Which PSU do you have? Sometimes PSUs come with additional 4 pins that you can snap together to form an 8-pin CPU connector.
