Netgear N150 WiFi USB not working
QuantumBit
Hey!
I just got windows on my new PC, and I want to start using it, but it has no WiFi to connect, so I found this old netgear n150 in a cabinet and tried connecting it. Nothing shows up, but on my old computer it does, any idea what happening?
EDIT: I just checked it isn't windows 10 compatible
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
Download drivers for it off the internet.
I would recommend getting a new PCIE wifi adapter if you need wifi though. USB adapters (especially older ones) are crap.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
I have the N300, honestly it's not bad.
GPU: XFX RX 7900 XTX
CPU: Ryzen 7 7800X3D
They're slow?
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
7 minutes ago, QuantumBit said:
They're slow?
It's not an issue of speed. USB adapters tend to inconsistent and far less stable.
PSU Tier List | CoC
Any recommended ones under $20? I wanted to get the one thats best selling and its $8..
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
