I just built a mITX i5 Kaby Lake w/ 970 & 1 SSD, 16gb ddr4... anyway I have a AX750 Corsair PSU.. my current issue is.. I'll be using my computer then poof randomly turns off and won't turn back on until the next morning....... The PSU I did buy was a refurb from Corsair but really...................... Help :D
https://linustechtips.com/topic/728335-power-supply-failure/
If it's refurb, it probably was returned because of this issue. I would check that all the cables are plugged in well, check temps, and contact Corsair if everything else doesn't fix the problem.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/728335-power-supply-failure/#findComment-9260392
Also if you happen to have a spare PSU around or if you can borrow from someone you know to see if it is the power supply and not for example a motherboard issue
Quote and/or tag people using @ otherwise they don't get notified of your response!
The HUMBLE Computer:
AMD Ryzen 7 3700X • Noctua NH-U12A • ASUS STRIX X570-F • Corsair Vengeance LPX 32GB (2x16GB) DDR4 3200MHz CL16 • GIGABYTE Nvidia GTX1080 G1 • FRACTAL DESIGN Define C w/ blue Meshify C front • Corsair RM750x (2018) • OS: Kingston KC2000 1TB GAMES: Intel 660p 1TB DATA: Seagate Desktop 2TB • Acer Predator X34P 34" 3440x1440p 120 Hz IPS curved Ultrawide • Corsair STRAFE RGB Cherry MX Brown • Logitech G502 HERO / Logitech MX Master 3
Notebook:  HP Spectre x360 13" late 2018
Core i7 8550U • 16GB DDR3 RAM • 512GB NVMe SSD • 13" 1920x1080p 120 Hz IPS touchscreen • dual Thunderbolt 3
https://linustechtips.com/topic/728335-power-supply-failure/#findComment-9260495
If your computer RANDOMLY turns off it is likely not an issue related to PSU, rather something with motherboard or another system component. If PSU isn't enough, it will shut down abruptly when put under heavy load.
"Rawr XD"
https://linustechtips.com/topic/728335-power-supply-failure/#findComment-9260825
Refurbished Corsair PSUs are refurbished in-house so I doubt OP was sold a defective PSU.
As @Aniallationsaid, PSU failures are often the culprit when the system shuts down under stress when the PSU is suddenly no longer capable of providing the load the system needs, which it may have been capable of at one point.
https://linustechtips.com/topic/728335-power-supply-failure/#findComment-9261712
Word of advice: don't buy refurbished PSU's..
Either way, troubleshoot to see if you can fix the issue. More than likely if your system is shutting down then it is indeed failing, I had the same on one of my old PSU's. I'd RMA it, assuming you haven't already voided your warranty. Corsair is great about replacing PSUs
https://linustechtips.com/topic/728335-power-supply-failure/#findComment-9261898
