replace the board under warranty is your best option if you can.
Otherwise get a usb one, like this on https://www.startech.com/Networking-IO/usb-network-adapters/USB-3-to-Gigabit-Ethernet-NIC-Network-Adapter~USB31000S
To replace the actual onboard NIC, you'd need some series soldering skills.
If your board is still under warranty, RMA it. If not, best option is to get a USB 3.0 to Gigabit ethernet adaptor.
