Hi all, here's my parts list. I've ordered them all, just the Graphic Card and Monitor didn't reach me yet. Anything else to add to my part list?
https://pcpartpicker.com/user/steve-kon/saved/FgBbvK
CPU: Intel Core i5-6600K, Motherboard: MSI Z170A GAMING M5, RAM: G.Skill DDR4 2 x 8GB GPU: MSI GTX 1070 Gaming X, Case: Cooler Master MasterCase 5
Storage: WD Blue 1TB, Samsund 850 EVO 250 GB, PSU: Corsair RM 750X, Display(s): BenQ BL2710PT: Cooling: Thermalright True Spirit 140 Power
Mouse: Gamdias DEMETER II- 3200DPI Gaming Mouse, Operating System: Windows 8.1
https://linustechtips.com/topic/728010-new-build-help/
1 minute ago, RKRiley said:
Power supply is a little overkill, and that monitor seems way too overpriced for 1440p 60hz.. but other than that its fine.
He's already ordered everything. and everything there is overpriced; the cooler, the RAM, the SSD, the GTX 1070, the case, and the power supply. The monitor is the worst offender of them all. However, there's little we can do about that now that he's ordered the parts.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/728010-new-build-help/#findComment-9256718
$800 for a 60Hz 1440p monitor? Wut?
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/728010-new-build-help/#findComment-9256719
The power supply is a future proof let's say. I bought the monitor for around Rs. 37000($542). And i'm looking for a UPS, but not sure how to select one. A user said APS ones are better, so i'm checking them.
https://linustechtips.com/topic/728010-new-build-help/#findComment-9256721
Not even Freesync/Gsync but at least it has built in speakers lol hope they are good
https://linustechtips.com/topic/728010-new-build-help/#findComment-9256727
Any reason for a UPS?
I guess $542 isn't bad as you're not from the States or Europe :P
https://linustechtips.com/topic/728010-new-build-help/#findComment-9256728
I've got them at lower prices than it shows on pcparticker.
https://linustechtips.com/topic/728010-new-build-help/#findComment-9256730
Future proofing doesn't exist, but in this case it kinda does (but even then 550W would allow for 1070 SLI in the future).
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/728010-new-build-help/#findComment-9256742
It's barely $200 less than a Predator x34,
https://linustechtips.com/topic/728010-new-build-help/#findComment-9256758
A keyboard, mouse, and Windows key? Make sure you get the most expensive Windows Key you can find.
https://linustechtips.com/topic/728010-new-build-help/#findComment-9256762
It isn't even IPS, or rated for colour accuracy. Also, 12ms response time.
https://linustechtips.com/topic/728010-new-build-help/#findComment-9256764
Yeah, we have frequent power cuts. And I needed a 1440p IPS panel, and they are hard to get without getting expensive.
https://linustechtips.com/topic/728010-new-build-help/#findComment-9256767
It is an IPS panel.
http://www.benq.co.in/product/monitor/bl2710pt
https://linustechtips.com/topic/728010-new-build-help/#findComment-9256776
It costs me more than $1600, more than a thousand dollars than my monitor.
https://linustechtips.com/topic/728010-new-build-help/#findComment-9256785
Hmmmm...320watts for the 1070 alone underload, I'd not recommend 550Watts for dual 1070, 600Watts would be much nicer especially if any overclocking was to happen :P
Fair enough, since you're in...(India?), it would highly depend on what you have available in your country.
https://linustechtips.com/topic/728010-new-build-help/#findComment-9256791
9 minutes ago, InsertName said:
Monitor price?
I posted the price in the above posts, Rs. 37000($542).
https://linustechtips.com/topic/728010-new-build-help/#findComment-9256799
1 minute ago, InsertName said:
*Whistes*. I was thinking of getting one, and it cost $250.
Damn, that''s nearly half the price I bought but then again anything related to PC in India is pricey,
https://linustechtips.com/topic/728010-new-build-help/#findComment-9256816
Rip, that happens...even in places such as the UK where we have prices that are like 20% higher than it would be in the states :P
https://linustechtips.com/topic/728010-new-build-help/#findComment-9256825
Sometimes with pricey items I will buy it in the US and have it shipped here ;)
You're in the UK? How do you like our 20% import charges on anything over $40 in value and the duties charges?
https://linustechtips.com/topic/728010-new-build-help/#findComment-9256840
That explains a few things.
That's exactly what I did with my entire build besides the motherboard, case, and PSU. Screw Indian prices.
https://linustechtips.com/topic/728010-new-build-help/#findComment-9256856
