As much as I love all the modern minimal cases on the market today with large tempered side panels, I find that a lot of them are lacking placement for front IO peripherals like a CF card reader, usb reader or an optical drive. Do any of you have this problem or issue with them?
https://linustechtips.com/topic/727652-issues-with-modern-cases/
USB reader??
You mean USB ports?
https://linustechtips.com/topic/727652-issues-with-modern-cases/#findComment-9252311
2 minutes ago, alexcheetah said:
no I mean like a 2.5 inch card reader with additional usb ports.
those are so out of date though
AMD FX 6300 @ 4.6 Ghz CRYORIG H7 Asus M5A97 PLUS | HyperX Fury 8 GB DDR3 | PNY CS1311 120gb SSD WD Blue 1TB 7200 RPM EVGA GeForce GTX 950 Superclocked NZXT Source 210 Black EVGA 500B Logitech G Pro HP K3500 Wireless Keyboard |
https://linustechtips.com/topic/727652-issues-with-modern-cases/#findComment-9252333
Most cases I see have 2 or 3 5.25 bays for things like these. Also not many people use an optical drive these days anymore
CPU: i7-12700KF Grill Plate Edition // MOBO: Asus Z690-PLUS WIFI D4 // RAM: 16GB G.Skill Trident Z 3200MHz CL14
GPU: MSI GTX 1080 FE // PSU: Corsair RM750i // CASE: Thermaltake Core X71 // BOOT: Samsung Evo 960 500GB
STORAGE: WD PC SN530 512GB + Samsung Evo 860 500GB // COOLING: Full custom loop // DISPLAY: LG 34UC89G-B
https://linustechtips.com/topic/727652-issues-with-modern-cases/#findComment-9252337
What the heck is a 2.5" card?
Is that like a floppy disk?
Yeah most cases don't have SD card slots, and optical drives are pretty much obsolete so 5.25" bays are being removed.
https://linustechtips.com/topic/727652-issues-with-modern-cases/#findComment-9252338
I might have mean 5.25 inch drive bay but this is what I meant
https://linustechtips.com/topic/727652-issues-with-modern-cases/#findComment-9252356
i totally dont have this in my two optical bays:
yes, thats a BD burner, a multi card reader, a little shelf for a chinese remote (it remotely controls china ;)) and my WD black in the back there, sitting snugly in neopreen.
and in case you wonder, yes the card reader was harvested out a prebuilt and wrapped in electrical tape for safety reasons.
https://linustechtips.com/topic/727652-issues-with-modern-cases/#findComment-9252383
lol It's just that I do a lot of photography and a CF card reader is really convenient for me. Technically I don't need front io bays but then I would end up with a minimalist case with all the clutter of an optical drive and card reader on my desk....
https://linustechtips.com/topic/727652-issues-with-modern-cases/#findComment-9252394
that's why i got an R5, not only do i have space for a bluray cupholder, but i also have a multi card reader (helpful for 3D printing in my case, which is why i installed it) and a shelf for putting my chinese remote control on, so i can remotely control china :D (which then controls the power to vareous devices in my room ;))
https://linustechtips.com/topic/727652-issues-with-modern-cases/#findComment-9252416
The R5 is nice I looked at one recently I just wish they came with a tempered glass side panel, I'm a sucker for modern design.
https://linustechtips.com/topic/727652-issues-with-modern-cases/#findComment-9252437
My next case upgrade will be the Fractal R5 since I need at least two 5.25" bays for an ODD and hot-swap bay.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/727652-issues-with-modern-cases/#findComment-9252438
34 minutes ago, RKRiley said:
Yeah that'd go in a 5.25" drive bay
No I don't think it would, I'll show a picture of a more "recent" case that has one. (I used this same exact case in a build recently and I have a 2.5 in it)
Image result for thermaltake case with psu
ok so this isnt the case i used but it shows my example, see the smaller slot below the 5.25 slots?
https://linustechtips.com/topic/727652-issues-with-modern-cases/#findComment-9252487
It's a 2.5 slot drive but a have an adapter to fit it into a 5.25 bay, either way I'd like to see more modern cases with A drive slot.
https://linustechtips.com/topic/727652-issues-with-modern-cases/#findComment-9252541
Define R5 is great, check out my build.
As for the SD Card reader and optical drive, just mount it under your desk for a clean look:
My main computer:
i7 6700k || GTX 1070 || Asus Z170 RGB || C.M. Hyper 212 EVO || 16GB RAM || 256GB NVMe SSD || 500GB SATA SSD || 12TB total HDD || Define R5 Blackout || 850W PSU
More Details Below :)
CPU: Intel Core i7 6700k                             GPU:  EVGA GTX 1070 FTW                                  |  Motherboard: Asus Z170 Pro Gaming Aura
CPU Cooler: C.M. Hyper 212 EVO             RAM: 16GB Kingston Fury 4x4 DDR4 2400MHz         SSD:  Intel 256GB NVMe SSD & Plextor 500GB SATA SSD
Hard Drive:  WD 2TB Black, 2TB WD Blue, 8TB WD Red     Case:  Fractal Design Define R5 Blackout Edition   PSU:  Be Quiet! Dark Power Pro 11 850W
Additional Computer Parts: NZXT Hue for LEDs
Peripherals: Dell U2414H (x2) || Corsair Sabre RGB || Corsair K95 Platinum || Sennheiser 558's || Modmic
Pictures of setup:
https://linustechtips.com/topic/727652-issues-with-modern-cases/#findComment-9252617
  Hide contents
  Hide contents
I might do something like that although my pc is currently already under my desk.
https://linustechtips.com/topic/727652-issues-with-modern-cases/#findComment-9252745
You can still mount it to the bottom of the desk :P
Or just put an external one on top. I have a portable optical drive for the about once yearly occurrence that I need it.
My main computer:
Pictures of setup:
https://linustechtips.com/topic/727652-issues-with-modern-cases/#findComment-9252980
Almost all of those ports are obsolete and have bee replaced by USB.
If you need more IO, you can buy USB hubs that give you everything you need.
99% of people don't need more than a few audio jacks and USB ports on the front of their PC so manufacturers don't put in front bays to keep the case looking clean.
https://linustechtips.com/topic/727652-issues-with-modern-cases/#findComment-9253082
99% of people also make their own statistics... ;)
https://linustechtips.com/topic/727652-issues-with-modern-cases/#findComment-9253095
99% of statistics are irrelevant enough to be made up without consequence ;)
https://linustechtips.com/topic/727652-issues-with-modern-cases/#findComment-9253242
99% of statistics are too useless to fact-check.
https://linustechtips.com/topic/727652-issues-with-modern-cases/#findComment-9253249
99% of facts are too useless to make statistics for.
https://linustechtips.com/topic/727652-issues-with-modern-cases/#findComment-9253257
