so recently i had this problem with my computer where itll just restart randomly when under load. but after it not happening for a while its poped back up and ive looked at my voltage rails and they where at when i checked:
3.3 = 3.2
5 = 4.99
12 = 12.23
Are these too high and what should i do, these aret the exact numbers but its the best i could remember.
https://linustechtips.com/topic/725592-voltage-rails-too-high/
Those are fine. They're within 2% of what's expected. It's when you're over 10% you should start worrying.
EDIT: By "They" I mean the 12V. Lower voltages aren't harmful to the system, they just cause instability but the rest is still within 10%.
https://linustechtips.com/topic/725592-voltage-rails-too-high/#findComment-9230253
1 minute ago, SeeFights said:
but the pc is legit just restarting as soon as i start fallout 4
what is the wattage of your power supply, and what hardware are you running, you might not have enough power, might
The owner of "too many" computers, called
The Lord of all Toasters (1920X 1080ti 32GB)
The Toasted Controller (i5 4670, R9 380, 24GB)
The Semi Portable Toastie machine (i7 3612QM (was an i3) intel HD 4000 16GB)'
Bread and Butter Pudding (i7 7700HQ, 1050ti, 16GB)
Pinoutbutter Sandwhich (raspberry pi 3 B)
The Portable Slice of Bread (N270, HAHAHA, 2GB)
Muffinator (C2D E6600, Geforce 8400, 6GB, 8X2TB HDD)
Toastbuster (WIP, should be cool)
loaf and let dough (A printer that doesn't print black ink)
The Cheese Toastie (C2D (of some sort), GTX 760, 3GB, win XP gaming machine)
The Toaster (C2D, intel HD, 4GB, 2X1TB NAS)
Matter of Loaf and death (some old shitty AMD laptop)
windybread (4X E5470, intel HD, 32GB ECC) (use coming soon, maybe)
And more, several more
https://linustechtips.com/topic/725592-voltage-rails-too-high/#findComment-9230268
A little low from what I understand at least.
Voltage and vdroop are a little difficult to measure though, as a lot of the time sensors aren't even accurate. You'd need something to read straight from the line itself.
In example, my 12v is reading at 5v. If it was actually at 5v, my computer wouldn't be running right now.
What all have you tried so far to diagnose these crashes? Have you tried synthetic tests on individual components to rule out potential issues with them?
https://linustechtips.com/topic/725592-voltage-rails-too-high/#findComment-9230276
FX-8350
ASUS sabertooth 990fx R2.0
2x 960's
3 hdd
2 x 4 gb RAM
630w psu
ive had the PC for 2 years and its never happened.
https://linustechtips.com/topic/725592-voltage-rails-too-high/#findComment-9230277
if that means having spare parts to test the components no
https://linustechtips.com/topic/725592-voltage-rails-too-high/#findComment-9230285
What were you using to get these numbers? I would also re-look at the readings if you're doing it based on memory at the moment.
https://linustechtips.com/topic/725592-voltage-rails-too-high/#findComment-9230297
FX-8350
2x 960's
3 hdd
2 x 4 gb RAM
630w psu
Putting this through a power calculator, have you got an amazing overclock or something as that's only 400W so that shouldn't be a problem
https://linustechtips.com/topic/725592-voltage-rails-too-high/#findComment-9230298
nah no overclock i used to run one until it began and stopped and then the problem dispersed and has legit reaper ed
https://linustechtips.com/topic/725592-voltage-rails-too-high/#findComment-9230305
If you're using Windows 7, I would see about disabling automatic restarts on BSODs to see if this is a BSOD: http://www.howtogeek.com/howto/windows-vista/help-troubleshoot-the-blue-screen-of-death-by-preventing-automatic-reboot/
Or alternatively, you can look in Control Panel -> Administrative Tools -> Event Viewer -> Windows Logs -> System and look for "Errors" (This applies to Windows 8/8.1 and 10 in case you have those instead)
https://linustechtips.com/topic/725592-voltage-rails-too-high/#findComment-9230308
HAHAHAHAHA i opened event viewer it resarted
https://linustechtips.com/topic/725592-voltage-rails-too-high/#findComment-9230332
5 minutes ago, SeeFights said:
FX-8350
2x 960's
3 hdd
2 x 4 gb RAM
630w psu
The overall wattage may be acceptable for the PSU, but it may not have sufficient amperage to power two 960s. What is the specific model number of your PSU?
Also, by synthetic test, I mean stress testing. Things like AIDA64, FurMark, and OCCT.
https://linustechtips.com/topic/725592-voltage-rails-too-high/#findComment-9230334
the PSU is the 630w BeQuiet i cant remember the exact model number
https://linustechtips.com/topic/725592-voltage-rails-too-high/#findComment-9230350
https://linustechtips.com/topic/725592-voltage-rails-too-high/#findComment-9230356
So does it only crash when you put any real load onto the GPUs???
https://linustechtips.com/topic/725592-voltage-rails-too-high/#findComment-9230364
