Corsair AF140mm with z170 pro gaming
Solved by aisle9,
12 minutes ago, Nashiwa said:Ok thanks! But then if I use the splitter or the hub doesn't it mean that the fans will not be correctly detected by the Asus app?
I also noticed that there a fan_opt slot which is most likely used for CPU liquid coolers, and as I have an air cooler could I use that slot to plug the case fan?
If you use a splitter, only one of the two fans will be detected. The other will just run at whatever PWM setting the one that the app recognizes is running at.
Yes, you can use a CPU_OPT or FAN_OPT header for a case fan.
