My previous post in new builds and planning seems to have been misunderstood since i didn't give a budget, so this time, i will explain again. Basically, my work computer died(one in profile), the storage is still recoverable but the rest is all dead (i tested for hours) i need a completely new build (yes storage too, anyone here know if i can somehow use a ssd that has windows on it on another computer and still have it work the same?) and basically the entire set up. My company is moving and they are selling all of our office furniture, so we will be buying new stuff - i need a table, monitor stands, speakers, keyboard, mouse, chair, at least 2 monitors (they should look sleek) one of those huge mouspads and any other productivity office stuff you guys think would help
The max budget for all of this is 7000 dollars CAD - i would appreciate it if you followed this as this thread will be active for at least several days
also, i would like the colour scheme to be black and white and a case similar to the nzxt s340 elite or h440 or corsair carbide 400 white. Please no double sided windows as my cable management is decent at best and a window showcasing it would be catasrophic
also, could you guys include some case fans too, the led ones, dont care about brand - just for aesthetics
this build will be used for programming so lots of ram and cpu power - the gpu should just be there for aesthetics
https://linustechtips.com/topic/724043-full-setup-help-pls/
4K monitors are 1440p?
Size of the monitors?
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/724043-full-setup-help-pls/#findComment-9212471
mulitple monitors so size doesn't really matter - id say at least 24 inches - i don't really need 4k so  1440p and use money saved on other parts of the set up
https://linustechtips.com/topic/724043-full-setup-help-pls/#findComment-9212475
1 minute ago, deXxterlab97 said:
Does the table and stuff in the budget too?
yes, although 7000 CAD isn't really the max - since my last post got really misunderstood when i said the sky's the limit but don't go too overkill - i got 500 dollar builds :P
i'd say 9 grand is the ABSOLUTE maximum - but please, no intel extreme edition processors, stick with k or xeons
https://linustechtips.com/topic/724043-full-setup-help-pls/#findComment-9212503
1 minute ago, gtx1060=value said:
the 2 windows
What about an NZXT s340 Elite? it has a PSU cover so you can hide quite a few things down there
Personal build >  New-ish AMD main gaming setup
   PLEASE QUOTE OR @ ME FOR A RESPONSE xD
https://linustechtips.com/topic/724043-full-setup-help-pls/#findComment-9212504
Just make the list - im not really going on what i like - but what other people like and i'll see if i maybe like that style of cases too
https://linustechtips.com/topic/724043-full-setup-help-pls/#findComment-9212517
Is North York a bit far too you? Provost drive? There is an IKEA showcase there. Lots of options there.
Can't recommend you with sound so hope someone else can do it
CPU: Intel Core i7-7700K 4.2GHz Quad-Core Processor  ($471.98 @ DirectCanada)
CPU Cooler: be quiet! Dark Rock 3 67.8 CFM Fluid Dynamic Bearing CPU Cooler  ($85.98 @ DirectCanada)
Motherboard: Asus PRIME Z270-P ATX LGA1151 Motherboard  ($172.02 @ shopRBC)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3200 Memory  ($134.99 @ Newegg Canada)
Video Card: EVGA GeForce GTX 1080 8GB FTW DT GAMING Video Card  ($852.48 @ shopRBC)
Case: NZXT S340 Elite (White) ATX Mid Tower Case  ($123.95 @ Vuugo)
Power Supply: EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($128.98 @ NCIX)
Monitor: Asus VX24AH 24.0" 2560x1440 60Hz Monitor  ($354.99 @ Newegg Canada)
Keyboard: Corsair K95 RGB Wired Gaming Keyboard  ($226.97 @ Amazon Canada)
Mouse: Corsair M65 PRO RGB FPS Wired Optical Mouse  ($68.99 @ Amazon Canada)
Total: $2621.33
Generated by PCPartPicker 2017-01-16 16:51 EST-0500
Did not pick the most expensive mobo, case or monitor. Just a regular 1440p IPS panel
Kept it white/black for you
https://linustechtips.com/topic/724043-full-setup-help-pls/#findComment-9212535
Total: $2621.33
watercooler? thermaltake riing or nzxt kraken x62? also, i want mroe ram and cpu performance - the gpu should really be for aesthetics - i don't game
https://linustechtips.com/topic/724043-full-setup-help-pls/#findComment-9212550
Ah then. Here is to better aesthetics
CPU Cooler: NZXT Kraken X62 Liquid CPU Cooler  ($209.99 @ Newegg Canada)
Motherboard: Asus PRIME Z270-A ATX LGA1151 Motherboard  ($213.38 @ shopRBC)
Video Card: Asus GeForce GTX 1060 6GB 6GB Dual Video Card  ($366.50 @ Vuugo)
Power Supply: EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($119.99 @ Newegg Canada)
Total: $2291.73
Generated by PCPartPicker 2017-01-16 16:56 EST-0500
https://linustechtips.com/topic/724043-full-setup-help-pls/#findComment-9212561
Total: $2291.73
not really sure about the 4 core and 16gb of ram tho - does kaby lake have a 6 or 8 core processor? or am i just limited to a 4 core?
https://linustechtips.com/topic/724043-full-setup-help-pls/#findComment-9212569
1 minute ago, MadOrc said:
https://ca.pcpartpicker.com/list/4XrNBP I tried to make it suitable for an office environment and it even has matching black and white everything by coincidence.
little confused about the cpu cooler and the different monitors but i like one of the monitors you chose - i may end up getting it
https://linustechtips.com/topic/724043-full-setup-help-pls/#findComment-9212583
No. Not yet. Well hope I made it right this time.
CPU: Intel Core i7-6800K 3.4GHz 6-Core Processor  ($561.50 @ shopRBC)
Motherboard: Asus X99-A II ATX LGA2011-3 Motherboard  ($313.96 @ shopRBC)
Memory: Corsair Vengeance LPX 64GB (4 x 16GB) DDR4-2666 Memory  ($660.26 @ NCIX)
Total: $3007.10
Generated by PCPartPicker 2017-01-16 17:00 EST-0500
https://linustechtips.com/topic/724043-full-setup-help-pls/#findComment-9212589
Total: $3007.10
thanks, i may end up using the 6800k or the 6900k is one better than the other in single core performance? obviously the 6900k has more cores but will it do better in things that don't use all the cores?
https://linustechtips.com/topic/724043-full-setup-help-pls/#findComment-9212602
Biggest blackest build I could make.
CPU: Intel Core i7-6800K 3.4GHz 6-Core Processor  ($573.32 @ Amazon Canada)
CPU Cooler: be quiet! DARK ROCK TF 67.8 CFM Fluid Dynamic Bearing CPU Cooler  ($125.22 @ NCIX)
Motherboard: MSI X99A GAMING PRO CARBON ATX LGA2011-3 Motherboard  ($429.99 @ Newegg Canada)
Memory: G.Skill Ripjaws V Series 32GB (2 x 16GB) DDR4-3200 Memory  ($254.99 @ Newegg Canada)
Storage: Samsung 960 Evo 250GB M.2-2280 Solid State Drive  ($205.97 @ NCIX)
Storage: Mushkin Reactor 1TB 2.5" Solid State Drive  ($304.99 @ Newegg Canada)
Video Card: Asus GeForce GTX 1050 Ti 4GB STRIX Video Card  ($229.99 @ NCIX)
Case: NZXT S340 Elite (Black) ATX Mid Tower Case  ($129.98 @ NCIX)
Total: $2374.44
Generated by PCPartPicker 2017-01-16 17:02 EST-0500
no peripherals included, I have yet to get to it.
https://linustechtips.com/topic/724043-full-setup-help-pls/#findComment-9212605
I think 6800k will perform better a bit. But Ryzen is releasing soon
http://cpu.userbenchmark.com/Compare/Intel-Core-i7-6900K-vs-Intel-Core-i7-6800K/3605vs3607
https://linustechtips.com/topic/724043-full-setup-help-pls/#findComment-9212618
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler  ($144.99 @ DirectCanada)
Motherboard: MSI X99A GAMING PRO CARBON ATX LGA2011-3 Motherboard  ($429.99 @ DirectCanada)
Memory: Corsair Dominator Platinum 64GB (8 x 8GB) DDR4-2400 Memory  ($589.99 @ Amazon Canada)
Storage: Samsung 960 Evo 500GB M.2-2280 Solid State Drive  ($329.00 @ shopRBC)
Storage: Western Digital BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive  ($154.99 @ Newegg Canada)
Video Card: EVGA GeForce GTX 1070 8GB SC GAMING ACX 3.0 Black Edition Video Card  ($509.99 @ Amazon Canada)
Power Supply: SeaSonic PRIME 750W 80+ Titanium Certified Fully-Modular ATX Power Supply  ($219.99 @ Newegg Canada)
Monitor: BenQ GW2765HT 27.0" 2560x1440 60Hz Monitor  ($399.99 @ Amazon Canada)
Keyboard: Ducky ONE Wired Standard Keyboard  ($155.97 @ NCIX)
Mouse: Logitech G602 Wireless Optical Mouse  ($90.98 @ DirectCanada)
Total: $4117.35
Generated by PCPartPicker 2017-01-16 17:04 EST-0500
https://linustechtips.com/topic/724043-full-setup-help-pls/#findComment-9212623
