Best 80mm fans?
Solved by WoodenMarker,
1 minute ago, sazrocks said:Alright then, I think Ill go for one of the Noctuas. Can you explain the difference between those two?
The NF-A8 is an update to the R8 with slight improvements across the board including better performance, lower noise, and better bearings among other things.
Featured Topics
bluesheep ·
Posted in Troubleshooting0 -
RvG Iced ·
Rogers24 ·
Posted in Troubleshooting3 -
TurkishBTW ·
Posted in Peripherals0 -
1
kennethk ·
Posted in Peripherals1
