I just got a Gainward GTX 560 TI Golden Sample, the gpu has 2x6pin power connectors and comes with 2x single molex to 6pin adapters out of the box.
But there is a warning on the card, says:
STOP! You Must connect this graphics board to the computer's power supply, Connector's options: 1x4pin, 1x6pin, 1x8pin, 2x4pin, 2x6pin, 2x8pin, 1x8pin + 1x6pin.
Really you can connect any combination of powers connectors to it? First time I ever se something like this.
Second, it comes with 2x single molex to 6pin adapters, can a single molex really provide 75w? I used a molex to 6pin adapter for years now, but it was a 2 molex zo 6pin (Y cable).
PSU is forton 450w, 24amps on +12v rail, old but good, runned a 8800gt without problems (power hungry monster gpu).
Corsair VS 550w comming soon.
https://linustechtips.com/topic/72261-gpu-power-connectors-confusion/
So the manual is saying you either connect one connector or two connectors?
That seems strange but if I were you I would just put two 6 pin to be safe. The reference card was designed to run off of 2x6pin so I can't see why this one would not.
"If you do not take your failures seriously you will continue to fail"
Yeah I know it's always better to plug the native 2x6pin, but that warning is the strangest thing ever, maybe it's a generic they put on every card?
Also, the card came with single molex to 6pin adapters, is it safe to use those or I should get a double molex to 6pin? (Y cable)
As far as I know the molex can provide up to 40w, and 6pins are 75w.
The GPU is rated at 160w tdp, so 75w from the pci-e slot and then 42,5w from each 6pin?
EDIT
Bah going to buy a double molex to 6pin, not going to risk.
