Help monitor shopping
Mr_Knight_
Hi im uprgrading my old lenovo 24 inch monitor and i don't know witch size gaming monitor to buy with 1 ms. Any recomendations for size, rezolutions, brands.
my grafhics card is gtx 1060 extreme gaming
Any 1080p 144hz should do fine
Asus PG248Q maybe
Asus PG248Q maybe
would an 27 inch be good to for gaming. like benq gaming monitor
2 minutes ago, Thread212 said:
U should just ignore response time because they are not worth comparing and there's no real standard on how to measure them.
Maybe if u can tell us ur budget then i can recommend one.
my budget  for monitor is 300€
27 inches imo is too large for 1080p
1 minute ago, Thread212 said:
Asus PG248Q is good enough since u have nvidia card so u can utilize g-sync but it may overbudget.
27 inch is too wide for 1080p screen resulting in a less sharper looking images.
24inch its the sweet spot.
thanks i will gor for 24 inch
